585,931 active members*
5,100 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > What type of tool holder is this???
Results 1 to 13 of 13
    Hi all I am new to the CNC mill stuff, I just acquired a SuperMax YCM-40 CNC Mill. I am trying to identify what type of tool holder this machine is using so I can get more. I have googled it but all I get is ran around in circles and no answers. I been to a few shops in the area and they have no idea but think it is a 40 taper. I have only used R8 type holders in the past.
    This has the numbers 40 EM 0.375 E it appears to have a 1/2" thread, Any help here would be greatly appreciated.
    Aug 2008
    Looks like an Erickson Quick Change or NMTB #40 taper, can be used with a draw bar
    or locking nut at nose of spindle.. That would be my guess at least.
    Dec 2008
    3109
    It is a 40 Taper holder, for a manual milling machine and uses a drawbar placed thru the spindle, with 1/2" BSW os UNC thread into the rear of the holder, to secure it in the machine
    The pull-stud is replaced with the extra bit on the back of the taper making it useless for a CNC machine
    Hi Clancy64 thanks for the reply, can you tell me what is the difference in NMTB #40 taper, Cat-40 and BT-40?
    Hi Superman thanks for the reply. This is a CNC machine, it had a tool changer on it but was removed by a previous owner. This is the toolholder that was in the machine. I am trying to find out what I need to buy so I can get busy using this machine.
    Dec 2008
    3109
    This is a link to Iscar Toolholhers to look at, this is for reference only, you will be able to buy cheaper ( sorry, it is a metric e-catalogue )( you may find inperial with a "kennametal tool holder" search )
    First, compare your tooling to this link, it has drawings of different tapers etc so that you know what to buy
    You may have a #30 taper, but it is marked as a "40" endmill side lock for a 3/8" shank tool
    Steve
    Thanks Steve that drawing helped a lot it measures out very close to the 40 NMTB.
    Jun 2009
    12
    Quote Originally Posted by Michael Turner View Post
    @ michael
    as I know, this is NT 40 side lock,
    the diferent is the tapper degre ,
    u can find from google, the tool suplier , like
    NIKEN ,BIG DAISOWA ,MITSUBISHI ,etc from japan ,AW from taiwan.
    Dec 2008
    3109
    Quote Originally Posted by asen59 View Post
    @ michael
    asen,
    I think you are incorrect, all tapers are 7" in 24", the gauge diameter dictates the taper #
    Go back to my last post and link to the "drawings of different tapers"
    Jan 2007
    206
    Smile 40 taper is 40 taper
    You can use any 40 taper tool holder in the spindle. the difference is the length of the drawbar and its thread. your best option would be CAT V flange because it is the most popular in the USA. it has a 5/8" -11 thread and does not have the small neck at the top. if the drawbar you have now works and is of good length, buy cat 40 holder and lay side by side. measure the difference in length and machine a new drawbar to fit, if you have CNC lathe make about 5 or 6 and keep for spares, the threads will wear out in time. used to run mill similar to yours with out tool changer. the shop had a quick change tool holder that stayed in the spindle and with a 1/4 turn the adapter could be changed out quickly by hand to use different drills and cutters, the stick out was about 2" longer than normal end mill holder but was still fairly ridgid. I hope this helps you get your machine going and covers your floor with chips and coolant!!!!!
    Good Luck
    The Farmer
    Apr 2008
    211
    It's a ISO 40 holder it needs a shorter drawbar than BAT40
    Mar 2008
    443
    There is little reason to make a new drawbar and start using CAT40 holders where NMTB 40 holders belong. In fact, the reason to stick with NMTB holders is that there's millions of them out there for cheap money! That machine doesn't need (and can't use) the main features of CAT40, which is the V-flange for a tool changer and (often) better balance for high speed operation.
    Why buy brand new holders when you can get mint condition older ones for "pennies on the dollar"? A friend of mine in Vermont has a number of them for sale. Look up Springfield Tool Supply of North Springfield VT. He's got an Ebay store, but that's only about 5% of his inventory.
    Nov 2008
    129
    Din 2080 (ISO 40)
    What you have is a standard din2080 sidelock with imperial tapping (also called ISO 40). So please ignore cat & BT or din 69871 as these are for use with CNC machine fitted tool-changers on cnc machine.
    As you have a manual drawbar, you could consider changing the draw-bar to 16mm if you cannot obtain these sidlock toolholder with imp/tapping.
  1. WTB: Erickson Type 419e / DA18 collet holder for MT3 taper
    By pjm in forum Want To Buy...Need help!
    Last Post: 04-19-2009, 11:35 AM
  2. what is this tool holder for
    By bassmastrbw96 in forum CNC Tooling
    Last Post: 09-07-2008, 03:11 AM
  3. T slot tool post with drill bit tool holder
    By brucesu1 in forum CNC Tooling
    Last Post: 06-09-2008, 11:04 AM
  4. Slot Cutter Holder Arbor type, cant find??
    By mgb1974 in forum MetalWork Discussion
    Last Post: 03-10-2008, 01:36 PM
  5. Km-3P Tool holder
    By woodr004 in forum HURCO
    Last Post: 09-17-2007, 02:24 PM
