585,908 active members*
3,657 visitors online*
    Apr 2003
    95
    Setting Backlash with Turbocnc
    Hello group,
    I am running a Taig mill with Turbocnc and have noticed I have a backlash problem with the machine and have tried to adjust it on the machine and have not quite got it all worked out.
    My first question is, what is the best way to measure backlash to see exactly how much the machine is out?
    Then do I just type the amount it is out into the correct place in Turbocnc?
    Thanks for all the help!
    Eric
    Mar 2004
    1806
    Hoss did an excellent video a while back on how to measure backlash. Try doing a search to find it. Then yes, type the amount in in the ini file and don't forget to reset the port before you try it.
    Remember, backlash setting in software is for a very minor amount, your best bet is to eleminate it to begin with.
    Art
    AKA Country Bubba (Older Than Dirt)
    Apr 2003
    95
    Thanks Bubba,
    I have tried to eliminate the backlash on the machine to the point of about pulling my hair out so I will try to fix it in the software until I feel like giving it another go at the machine.
    Eric
  1. Setting Up TurboCNC
    By Davedbq in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-25-2008, 07:46 PM
  2. Setting Limits In TurboCNC? Also convert line drawings?
    By Patrick_M in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-02-2008, 06:21 PM
  3. Replies: 8
    Last Post: 03-10-2008, 09:35 PM
  4. Setting up TurboCNC
    By itsme in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-24-2005, 03:17 PM
  5. Help setting up turbocnc 4.01..??
    By lurch in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2005, 09:57 AM
