Dear all,
Can you tell me how to force X/Y/D signal of PMC (FANUC 0i-TC system ) ?
I press PMC - PMCDGN -state, and select the signal, then press On or off, but don't ge the result .
Can you tell me why ?
Thanks for all support !
Dear all,
I belive that you can use the Fanuc Ladder III software connected to your machine and change the ladder states/signals "online" with the machine.
I never did it, so I can be mistaken !
Filipe
TO force an input or output you need to ladder force enable first , what is the software version you are using , at the moment you will switch on the machine you will see fanuc Oi Tc and a version of software like RA .... please mention so I can help you Regards [email protected]
you need to enter the PMC setting screen,make the IO Force enable.
don't worry,it's easy .
