I recently bought a 1993 Bridgeport EZ Trak SX 2 axis mill in very nice condition from a previous owner I know was having no problems with the machine. It was wired for 208VAC and I made the changes described in the manual (transformer taps and jumpers) to set it up for 220VAC operation. When I powered it up the first time everything seemed to work OK during a brief test run. Shortly after we set up a job and proceeded to make a light cut 16" along the X axis in some soft material. Halfway through the cut, the spindle shut down and the display showed the message "Emergency shutoff", despite the fact that the emergency shutoff button had not been touched. We restarted the program and experienced the same thing a second time. The manual is unclear as to what produces this spontaneous shutdown. One factor that I think might be related is that the actual voltage in my building tends to be high(250VAC) most of the time. Before I lean on the power company to try to get them to reduce the voltage or spend my own money to condition the voltage, I would like to have a better idea as to what the system is telling me when this shutdown occurs - Is this a response to the motor drawing higher current at the elevated voltage, is it telling me that the CNC control electronics (which are run by single phase 110VAC via the internal transformer) don't like the ~125VAC, or is it unrelated to the elevated voltage. Any thoughts on this would be appreciated.
