585,708 active members*
3,902 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Can I index the spindle on a TL-1?
Results 1 to 7 of 7
    Dec 2006
    75
    I have a one off project that would require me to index the spindle on my TL-1 and then have it hold, then index again and hold etc. Can I do that on this machine? If so can someone explain briefly how? I would appreciate the help, I have never tried anything lke that.
    Hercules
    2008 TM-1, 2008 TL-3, 2009 TL-1, 2010 VF-2YT
    Jul 2005
    340
    try M19 code with a Pxxx when works check the manual.
    __
    Peter
    Feb 2009
    6028
    TL1
    Don't think so. Usually only live tool lathes can. Our TL1 can not for sure. Pretty basic machine.
    Nov 2008
    76
    Have you thought of making a fixture or something like a simple indexer?
    Sep 2007
    56
    Index
    Don't know about a TL-1...
    But I do know that if you buy the bar feeder with your lathe from haas,
    spindle indexing is included. They do it so you can index the spindle for
    hex stock bar feeding.
    I have it on my SL-20...they didn't turn it on from the factory...but the
    codes were in my setup papers...so I had service guy turn it on when they installed machine.
    S
    Dec 2006
    75
    Thnaks guys I figured it out. I was searching in my manual and on the net for TL-1 "spindle indexing" since I was thinking of an indexing head. Turns out I found they call it "spindle orientation". So I turned on the 200 hour try out option for "spindle orientation" and then used M19 Rx.xx and it worked perfectly. Got my part made and only used up about 2 of the free 200 try out hours.
    Hercules
    Jul 2005
    181
    Don't forget to turn the option off after using it to not loose your 198hr. And you must reboot the machine after that.
  1. Has anyone here used 1st INDEX ?
    By DaveJ-FTM in forum Complaints and Praise Discussions
    Last Post: 04-15-2009, 06:21 PM
  2. Spindle RPM control - Do I need an index pulse?
    By Lexx0001 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-27-2009, 07:42 AM
  3. rw14 - Spindle will not index on toolchange
    By 66 AC COBRA in forum Milltronics
    Last Post: 04-16-2007, 04:51 PM
  4. Taig / Digispeed XL spindle index sensor
    By Dfennell in forum Taig Mills / Lathes
    Last Post: 01-02-2007, 06:23 AM
  5. spindle index, encoder, home/limit switch
    By Wm McNett in forum CNC Machine Related Electronics
    Last Post: 01-13-2006, 01:39 PM
