585,991 active members*
4,664 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Any CNC machines as easy to program as ProtoTRAK machines are?
Results 1 to 7 of 7
    May 2007
    320
    I am wondering if there are any other machine cnc controls as easy as the ProtoTRAK control...
    I like how easy it is to make and change programs on the ProtoTRAK for small-lot runs and prototyping stuff.
    Feb 2008
    51
    Not that I have run across, most people who have run regular cnc machines have a hard time with them because it is so easy( no g code) enjoy your proto trac I have been using them since the early 90,s
    May 2007
    320
    how are the prototrak mills.. like the DPM series? are the knees mills okay?
    Feb 2008
    51
    I have a fhm 3 axis bed mill smx and a retrofit 2 axis bridgeport I have had no problems been using proto tracs since the early 90,s
    May 2007
    320
    where are you located? I'm looking to buy a prototrak bedmill or sub work out if you are near..
    Feb 2008
    51
    severn maryland call thomas harpine410 487 1364 he is the local dealer
    Feb 2008
    51
    severn maryland call thomas harpine 410 487 1364 he is the local dealer
  1. Are slant bed machines superior to flat bed machines?
    By Quickers in forum Uncategorised MetalWorking Machines
    Last Post: 06-01-2019, 09:11 PM
  2. Posting to Prototrak machines
    By pilsnerglass in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-09-2009, 03:02 PM
  3. REPLACE SYIL MACHINES WITH AMERICAN MADE MACHINES
    By heilcnc in forum Benchtop Machines
    Last Post: 08-24-2009, 07:53 AM
  4. easy cut machines and software
    By pipelathe in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-10-2009, 07:38 PM
  5. Replies: 9
    Last Post: 11-06-2007, 03:29 PM
