585,975 active members*
4,589 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers > Help! I deleted the firmware from my DSP controller
Page 4 of 5 2345
Results 61 to 80 of 82
  1. #61
    Mar 2009
    90
    Hello i had the same problem with my dsp maxim speed 10000mm/m. the answer is simple find the "output pulse" in the menu and change the "pulse width" smaller i think that now is 7 in your case try it 5 and the see what is happened if it's not enought try 3
  2. #62
    Jan 2013
    Hi All
    Willem here from South Africa
    We have Ruijie CNC maschine with the DSP 501n Controller
    I have error screen on my DSP controller handset.
    "C driver error, press any button to reboot ......"
    It seems to be frozen on this message no reboot.
    I run Windows 7 and it does not reconize the controller and the sentek software seems to be useless.
    Please if one of you cnc boffins out there could assist me it will be awsome thanks
  3. #63
    Jun 2004
    10
    Hi
    Does anyone still have this problem? I got this problem with my DSP Controller this weekend. After a lot of struggle I found out that I had enabled the setting for hard limit switches in the Machine setup. This was done deliberately because I believed that I had hard limit swithes, doubling as both Hard limit and Home park switches. My chinese mill only have Home Park switches. Hard limit switches are two switches at every axes one in + and one in - direction. Home park switches are only one switch at each axes and at the Home Park Position end.
    regards
    nogeso
  4. #64
    Jun 2004
    10
    Hi again
    the problem I am referring to in my posting above is the following: error message "Z-hard Limit trigged, STOP to reboot, DELETE to adjust z position".
    Forgot sto specidy
    Regards
    nogeso
  5. #65
    Mar 2009
    90
    Pleas explain the exact steps you did and i will help you resolve your problem
  6. #66
    Jun 2004
    10
    hi mecanicu
    As I wrote in my email I have solved the problem - in machine setup disable the hard limit switches and the problem is solved
    regards
    nogeso
  7. #67
    Oct 2016
    4
    Re: DSP problems!!!! please help
    -Pulse equivalence: x400 y 400 z800 There is an error !!! x,y,z 163,05 no 400 !!!!
  8. #68
    Oct 2016
    4
    Re: help me I want firmware or BOOT RZNC-0504
    Do the hard reset! Following ... turn off the machine!
    Hold down the button on RZNC (OK) when you turn on the machine ...
    * select Reset, factory set ..
    * Enter the settings for your machine ...
    old problem would be removed
  9. #69
    Jun 2016
    6
    Re: Help! I deleted the firmware from my DSP controller
    Hi, I badly need those file so i can recover my DSP controller program. I have accidentaly deleted my DSP software, and now, my screen is blank.
  10. #70
    Oct 2016
    4
    what has to do with the DSP window ???
    I do not understand what's going on ...
  11. #71
    Jun 2016
    6
    my DSP windows shows nothing, only blank screen. please send to me your email so i can send all pictures.
  12. #72
    Oct 2016
    4
    ok ... turn off the machine and ON . Software should be drawn into the device itself ...
  13. #73
    Mar 2013
    4
    Somebody send me label and menu file
    0501_1.0_Menu E.txt
    Zhblabel501_E_V17.label
  14. #74
    Mar 2018
    I've cnc routet cutting machine and dsp 501. I need in making diagrams transfering it to dsp and then operating cnc router. Your instructions will be much appreciated.
    Sent from my SM-J700M using Tapatalk
  15. #75
    Talking Re: Help! I deleted the firmware from my DSP controller
    Quote Originally Posted by Big S View Post
    The DSP program can be reinstalled using the signtek software, (been there done that) you also need the software file( it should be something like 'Setup(RZTH501)_E_200721'
    Cenicero, can you pm me your email address and I will send you the English version of the host program. Its 6MB+
    Shannon.
    I know that this post is old
    I need please the signtek software.
    Please can you send me?
  16. #76
    Re: firmware
    Would you be able to send it to me too?
    - - - Updated - - -
    Can you reload the link?
  17. #77
    Jul 2020
    Post Re: Help! I deleted the firmware from my DSP controller
    Quote Originally Posted by cenicero View Post
    Is that an executable file? Like 'Setup(RZTH501)_E_200721.exe'?
    I have the following files:
    0501_1.0_Menu C.txt (1.91KB)
    0501_1.0_Menu E.txt (2.07KB)
    RZNC-D5416-1.2(zhb36)_init.NEWBIN2 (63.2KB)
    RZNC-D5416-1.2(zhb981)_normal.NEWBIN2 (172KB)
    zhbLabel501_C_v17.label (24.4KB)
    zhbLabel501_E_v17.label (29.0KB)
    Maybe the file that you are talking about is one of those '.NEWBIN2'? Which one of them?
    I sent you a PM with my email address.
    same problem for me
  18. #78
    Jul 2020
    i have same problem please help me
  19. #79
    Nov 2011
    5
    I can solve RichAuto A11E/S and 0501 DSP BLANK DISPLAY PROBLEM, SEND IT TO ME Phone & WhatsApp No. +919845352938
  20. #80
    Jul 2021
    5
    Quote Originally Posted by nogeso View Post
    hi mecanicu
    regards
    nogeso
    Hello how did you fix the problem?
Page 4 of 5 2345
  1. Opinions: Integrating Nikken 5AX-120 4th/5th axis on Excello 605 with Linux CNC
    By torinwalker in forum Uncategorised MetalWorking Machines
    Last Post: 04-16-2013, 06:44 PM
  2. I deleted the firmware from my DSP controller
    By ravafenice in forum Commercial CNC Wood Routers
    Last Post: 09-10-2011, 07:06 PM
  3. Deleted. NT
    By g-codeguy in forum MetalWork Discussion
    Last Post: 10-01-2008, 02:31 AM
