586,005 active members*
5,111 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Arrow error 9036 HELP!
Page 2 of 2 12
Results 21 to 39 of 39
  1. #21
    Dec 2022
    15
    Re: Cincinnati Arrow error 9036 HELP!
    Hi, How connection should open when cnc_com.exe is open on pc it just open to dos. Nothing can't wrote there. Cable is connected. And Control panel picture not continue anywhere. It leave searching for PLC program. Is some key what need push on control panel or what? Thanks for the good advice.
  2. #22
    Aug 2015
    32
    1) On the PC, start CNC_COM (refer to the "Arrow Serial Communications" procedure)
    2) Enter the test mode on the FNC controller. (Press the reset button on the power supply module and then press and hold the Run/Test button until the M8 led goes out on the memory module)
    3) On the FNC, select File Maintenance
    4) Select Copy File
    5) From file I:COMP.MC (the COMP.MC file must be in the same directory as the CNC_COM software on the pc)
    6) Select To file: C: COMP.MC
    7) Press the Data Entry key. The data should then start to transfer to the control.
    8) When the FNC says "Done", press the back arrow key to return to the test mode main menu.
    9) Press the reset button on the power supply module to reboot the control.
    10) The new comp file is now loaded onto the control.
    11) On the PC, press ALT and ESCAPE to exit CNC_COM
  3. #23
    Aug 2015
    32
    In your params file you have simulation mode selected and needs changing
    like this it should be
    G 7 'Global parameters
    ARROW 'Identification
    0.13 'Revision
    2nd Feb 1996 'Description
    0 'Language
    0 'Mode (0 = normal, 1 = Simulation)
    1 'Motherboard type
  4. #24
    Aug 2015
    32
    You should also have a main .cfg that needs changing the same
  5. #25
    Dec 2022
    15
    Many thanks, need test how go.
  6. #26
    Dec 2022
    15
    Hi, We are new with this machine. Machine not been in use long time. Memory card is empty. Need start from begin with this. I could find mentioned points 3 and 4 from FNC control panel. And this mentioned params file where that should be? Either main.cfg could find. Files what we have is download from this thread. Thanks for the good advice.
  7. #27
    Aug 2015
    32
    The files should be in the C drive.
    You have a C and D drive. The only thing that should be in the D drive is main.SOC do not touch this file or drive as you will break the memory module.
    Install the files into the C drive only.
  8. #28
    Dec 2022
    15
    Many thanks, need test how we manage.
    that earlier mention main.cfg not found these files.
  9. #29
    Dec 2022
    15
    Hi, Files copied to c: drive. Picture show what error come. Error 9001: Invalid system program parameter 7 press any key. This same come from begin number 7, then 8,9.11,12, and 33. After this not happen else. What can be reason? What need configure?
    Thanks for the good advice!
  10. #30
    Dec 2022
    15
    Quote Originally Posted by 12345678zxc View Post
    This can forget. Found reason. Now go forward to next problem...
  11. #31
    Dec 2022
    15
  12. #32
    Dec 2022
    15
    What might be reason that error 9036 come still even files is upload to machine? Error come 5-6 times after start and need go forward after push some key one-by one and the end machine start.
  13. #33
    Bonjour à tous.
    Même soucis que certains ici avec une cincinnati arrow 500 avec commande CT.
    Le logiciel cnc_com mis a disposition dans les messages précedant fonctionne t-il.?
    Pour le câble, lequel faut il utiliser.? Un câble RS232 qu'il faut recâbler absolument.?
    Une fois le câble connecté a la machine, il suffit juste via la commande ms dos d'envoyer les fichiers corrompus.?
    D'avance merci.
  14. #34
    Bonjour.
    j'ai pu finalement résoudre le problème pour la cincinnati arrow 500.
    J'ai pu entrer dans le systeme d'exploitation de la machine via le bouton run/test sur la carte électronique dans l'armoire de la machine.
    J'ai ensuite pu éditer le fichier qui était corrompu. Pour moi c'était le fichier main.plc à la ligne 3806.
    J'ai changé le caractère et j'ai ensuite redemarré la machine.
    Tout à bien fonctionné. Changement outil ok, rotation broche ok.
    Merci a ce forum pour toutes les informations.
  15. #35
    Mar 2008
    285
    gaetan16300 (Translated)
    Hello.
    I was finally able to solve the problem for the cincinnati arrow 500.
    I was able to enter the machine's operating system via the run/test button on the electronic board in the machine's cabinet.
    I was then able to edit the file which was corrupt. For me it was the main.plc file at line 3806.
    I changed the character and then restarted the machine.
    Everything worked well. Tool change ok, spindle rotation ok.
    Thanks to this forum for all the information.
  16. #36
    Hello. I told you that I had succeeded in restarting the cnc machine. But now I have an alarm popping up. This is alarm 9182 which indicates:
    error 9182: Z axis, quad encoder signal fault.
    Have you had this alarm, and how to solve this problem?
    Can this from Z axis drive or motor?
    thanks a lot for your help.
  17. #37
    Aug 2015
    32
    Did you get this error sorted 9036?
  18. #38
    Aug 2015
    32
    check all the connections that go to the spindle drive. There are some that are on a small metal serial connector and easily break.
  19. #39
    Aug 2015
    32
    This may be of use to someone the start up and tool setup instructions for the fnc controller
Page 2 of 2 12
  1. Arrow 750 with CT control error message 9036
    By DEAN-O in forum Cincinnati CNC
    Last Post: 02-11-2019, 01:17 AM
  2. Replies: 0
    Last Post: 11-25-2013, 02:13 PM
  3. New Cincinnati Arrow owner with servo error
    By mvas82 in forum Cincinnati CNC
    Last Post: 06-19-2013, 10:13 PM
  4. Cincinnati milacron 750 arrow error msg
    By A1 roper in forum CNC Machining Centers
    Last Post: 02-11-2011, 02:24 PM
  5. Cincinnati Milacron Arrow 750 Error Message
    By Nikon Phil in forum CNC Machining Centers
    Last Post: 02-11-2011, 12:08 PM
