585,997 active members*
4,784 visitors online*
Results 1 to 8 of 8
    Oct 2009
    Exclamation MAzatrol T32B Control
    I'm trying to revamp a QuickTurn 8N thats been sitting for some time (Its full of rat droppings!!) I get the following error on startup:
    Bus error
    Error at or near $004C0D96
    I've checked all connections and all seems to be OK. I suspect the problem is somewhere in the NC as the LEDs don't look OK. Another so-called tech worked on the mach before me and literally ran away, taking the manuals with him. Can anyone point me in the right direction.
    Jul 2007
    284
    What LED's are on on the MC116 board in the control?
    How long did the machine sit before you turned it on. There is a good chance the batteries dies during power off. It will be tough to tell because the batteries recharge on power up so they may read fine right now. If the batteries died then you will probably have to reinitialize the control.
    Apr 2009
    31
    Jan 2010
    Quote Originally Posted by onthebumper View Post
    Hi On the subject I have a mazak qt25 with the same control and i replaced the batteries and loaded the parameters and they start coming up with ** instead of numbers, also i have a parameter error alarm # 44 Please help! Thanks Jim Thinnsen 714 6121480 [email protected]
    Mar 2009
    109
    Quote Originally Posted by tntind.com View Post
    Initialize the control to get rid of the ****. Changing batteries and reloading parameters is not enough in this case.
    Jan 2010
    Unhappy
    Not to appear dumb, I am a chess master! LOL
    "Initializing" the control consists of doing what exactly?
    Thanks again for your help!
    Apr 2009
    31
    Hi
    Can you show me which the led is on or off ?
    Thanks !
    Jan 2010
    It is also dropping parameters and replacing them with ** how do I "initialize" the control? Thanks!!
  1. Mazak VQC-15/40 With Mazatrol CAM M-2 Control
    By bob1371 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-18-2014, 03:58 PM
  2. Mazak QT-8 with a T32B controller need help
    By Captdave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-18-2011, 04:18 PM
  3. One clean up pass after threading…T32B
    Last Post: 09-09-2009, 03:55 PM
  4. QT8/T32B Control
    By lovell110 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-01-2007, 01:26 AM
  5. mazatrol control
    By Fraggle in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2006, 11:58 PM
