585,971 active members*
4,075 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Problems with screen display on Fadal VMC 40 ???
Results 1 to 10 of 10
    Mar 2009
    27
    Just got a Fadal VMC 40 (1992) put into my garage. Powered up and screen display is going off and on (mostly off)....when on it is kinda fuzzy. Not sure what the problem is...any leads would be helpful....Thanks
    TMILLS
    Sep 2009
    181
    I will be able to fix your display (monitor) if you send it to me
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
    900
    Tmills--
    Have you checked the power going to the monitor fot the right voltage? Also, verify that the cables at the 1420 card in slkot #7 is solid in its connection and all wiring going to the monitor is properly connected.
    You might also try removeing the 1420 card and clean the gopld edge contacts and re-seating the card.
    Neal
    Sep 2009
    181
    Neal, I don't think that is the the problem. If the power is fluctuating, he will surly see that the light also flickering. Not only that if power goes below 90VAC (power input to the monitor) then only it will effect the display. Monitor has it's own 12 DC power supply so minor change in power won't effect the display.
    Mar 2009
    27
    I am running a rotary phase converter also (15HP) My buddy checked power to the machine and all looks great. I'm not a electric guy so I will have my buddy check power to monitor.
    Last night it stayed on for about 5 min. I adjusted the brightness and fixed the fuzzy look with the 2 knobs in back of monitor. Screen looked very nice and crisp. Then it flickered out and in....Then I hit the side of the monitor and it came back again...then lost again....Tried messing with some wires but nothing....thanks for your input guy's....anything else would be great.
    Thanks TMILLS
    Nov 2007
    78
    Sounds like cold solder joints somewhere. Typical for anything PCB based from the 80's and early 90's. Today, soldering is better and QC is alot better.
    I replaced my green screen CRT with an LCD screen. If you want to buy my old one I would let it go with shipping for $250. Includes the power supply board that attaches to the CRT chassis. My CRT screen had very minor screen burn. As in you cannot really see ghost print except with the power off. I can provide pics of the unit. If you happen to want to buy a new one, here is where Fadal parts are at http://www.omnivisionusa.com/replace..._mon_home.html
    LP1215H1N-P31 = $399.00 each
    Mar 2009
    27
    Thanks for all the input guy's.......I will consider it Fastfiero ...thanks
    I opened the back again and the large board sitting flat beneath monitor must have a wire loose.....I pushed on the board and the display lit up. Then after a while it went out again. I pushed on the board then it lit up again.......so I think I have narrowed it down to a loose wire or solder somewhere on the board.
    Thanks again guy's.I'm sure I'll have plenty more questions considering I havn't run a fadal in about 17 yrs.
    900
    Tmills--
    Glad to hear you found the connection issue. I have seen this happen before that's why I suggested checking all the wiring going to the monitor.
    Sounds like you're on the why to solving the issue.
    Neal
    Jul 2009
    317
    hhh
    Oct 2020
    4
    Alonex - CRT to CRT New Monitors Replacement, Repair & Refurbishment for Fadal VMC
    Dear Sirs,
    For your kind attention and ordering:
    http://www.alonex.com/pdf/AX-FDL.pdf
    http://www.alonex.com/pdf/AX-CRT.pdf
    B&Green/B&Amber/B&W Monochrome and Color New CRT Data Monitors are available for:
    Fadal VMC15-XT, VMC20, VMC45, VMC2016/L, VMC2216, VMC3016, VMC4020/A, VMC4020C, VMC4020HT, VMC5020A, VMC6030A, VMC8030,.. Vertical Machining Center, and for CNC88, CNC88HS, CNC32MP, CNC88, CNC88HS, CNC32MP Controls
    1 Year Warranty, 25 Years on Duty, That is Why no incompatible LCD Monitor is required!
    - 9", 12", 14", 15", 17", 21" CRT Cathode Ray Tubes.
    - Custom adaptation to any video interface.
    - Automatic Color Signal Killer in Black & White Mode (No color snow).
    - Flexible H&V Sync Generators.
    - New condition in factory package.
    Related services are listed herein:
    http://www.alonex.com/pdf/AX-REP.pdf
    http://www.alonex.com/pdf/AX-IPC.pdf
    http://www.alonex.com/pdf/AX-CON.pdf
    http://www.alonex.com/pdf/AX-MON.pdf
    http://www.alonex.com/he/ - Special Electronic & Computer Systems Repair & Engineering services in HE+EN
    http://www.alonex.com/ru/ - Special Electronic & Computer Systems Repair & Engineering services in RU+EN
    http://www.praftec.com/rd/ - Special Purpose HW/SW Design & Development services in HE+EN
    Welcome to your inquires and orders!
    Alonex ICEE Labs
    E-mail: [email protected]
  1. screen display readout
    By nigel2000 in forum Fanuc
    Last Post: 06-28-2013, 09:49 PM
  2. How to get G154 P1 to display on screen
    By Kool Parts in forum Haas Mills
    Last Post: 10-27-2011, 05:17 PM
  3. System Screen does not display
    By hutch07 in forum Fanuc
    Last Post: 01-29-2011, 06:12 PM
  4. mach3 display screen
    By woodman08 in forum Mach Mill
    Last Post: 08-18-2009, 05:45 PM
  5. Table display screen reversed?
    By bcnc in forum Mach Mill
    Last Post: 06-17-2007, 05:48 AM
