585,932 active members*
3,899 visitors online*
Thread: Lasers
Results 1 to 7 of 7
    Oct 2006
    41
    Wink Lasers
    I am just going to let the cat out of the bag here. For Fabtech this year we have LASER. 100-400W Co2. Video on our videos page. You may now start drooling. Cut kerf .0025". Much fun but sorry it's not cheap stuff. Just thought our faithful freinds here on the "zone" would love to know this.
    More details later.
    DT engineering.
    Feb 2007
    62
    So . . . how much?
    Oct 2006
    41
    Lasers
    2nd most asked question. I will see if you can guess the first.
    100 Watt - $40K
    240 Watt - $60K
    400 Watt - $100K
    I did warn you. There is a LOT of equipment required along with the beam delivery system. None of the parts are cheap. Big DC power supply, RF supply, Water chiller, etc.
    Jul 2006
    215
    Will that even cut 1/4" steel? I allways thought they needed more power than that.
    Oct 2006
    41
    Laser Bingo!
    Sure enough. The single most popular question when the word "laser" is mentioned is the one you asked. How thick? Well of what?
    Acrilic Plastic? ABS? Wood? PVC? Airbag material? Rubber? Cork? Gasket material? Steel? Stainless? Aluminum?
    To answer that would require a huge list matrix of size vs materials. Instead, you will find a useful tool online. Go to synrad.com and select "laser basics" at the bottom of the page . Then download the free calculator on the right next to "how much power do you really need?"
    Select a laser Watt rating and material. Then enter a thickness. If you go to far it will tell you. It will also give you a feedrate for that. It sure beats a few rough numbers.
    Dec 2006
    24
    IS more fast that plasma cutting sistem or only the best is that have better cut finish
    Dec 2006
    24
    it will can order how a kit by added to a plasma machine buyed before, or need new full machine and table?¿
  1. New to lasers
    By 918rbennett in forum Community Club House
    Last Post: 09-24-2009, 01:31 AM
  2. Lasers
    By Appalachiatools in forum CNC Machine Related Electronics
    Last Post: 05-05-2009, 11:39 AM
  3. New to lasers.
    By tommee10533 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-05-2009, 04:58 AM
  4. Adapting Lasers for CNC
    By Marc Soren in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-14-2005, 03:27 PM
