586,009 active members*
4,992 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 and SmoothStepper
    May 2006
    22
    Has anyone run a g540 with smooth stepper under Mach3?
    I have the two connected up and they appear to be 'lighting up' OK, but the RESET button on the screen won't work and if 'clicked' too often the computer freezes and I have to reboot.
    Feb 2007
    456
    They work great together. If you click the 'Reset' button or 'Feedhold' button too fast many external motion control devices will have a fit. I'm sure that will improve in the future. These buttons send specific signals to an external device if you press them really fast over and over the external device does not have enough time to process the first command and report back to Mach before the second one arrives. You only need to press 'Reset' or 'Feed Hold' once.
    If your G540 is not coming out of Estop mode it is because you do not have Mach configured correctly and/or you did not install the SS driver and plug-in. Go get the G540b.xml from Geckos site and save it in your Mach directory. It has ALL the settings for the G540 all ready done, but NOT for use with the SmoothStepper. To use the SmoothStepper with that profile start up Mach with MachLoader and select the G540B profile. When Mach starts fo to the second menu over and at the bottom of the list will be 'Reset Dev Sel...', click on that, click OK on the dialog box that pops up and then close down Mach and Restart it. When Mach restarts you'll get the licensing screen and then a Screen that says 'External Motion Controller found', select the SmoothStepper from the list and check the do not ask me again box. Now the SmoothStepper is set up to be your motion control device.
    Jeff Birt
    Mar 2007
    4
    I have tried the above suggestions, but I am still not up and running.
    there is a G540 XML file and a smooth stepper XML file, which one do I load first?
  1. G540 and Smoothstepper
    By escott76 in forum Benchtop Machines
    Last Post: 08-28-2009, 08:24 PM
  2. Dyna 2400 and SmoothStepper
    By Jeff-Birt in forum Benchtop Machines
    Last Post: 04-17-2009, 10:03 PM
  3. Anyone tried a Smoothstepper?
    By Ranscon in forum CNC Machine Related Electronics
    Last Post: 03-07-2009, 07:37 PM
  4. SmoothStepper and Mach3 setup
    By jeffmorris in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2008, 09:09 PM
  5. SmoothStepper Now available in Australia.
    By phomann in forum News Announcements
    Last Post: 06-13-2008, 02:24 AM
