Originally Posted by
bruiserba
IM TRYING TO SEND /RECIEVE TO A OSP5020L WITH A CNCGCODER PALM PILOT WHEN I SEND A PROG FROM LATHE TO PALM PILOT THE PROGRAM HAS A BOX AND DOLLAR SIGN IN FRONT OF PROG NAME THEN A % IT WILL NOT LET ME SEND THE PROG BACK TO LATHE CAN ANYONE HELP ME WITH WHAT IM DOING WRONG TO SEND A PROG TO THE LATHE THANKS.
First TURN YOUR CAPS LOCK OFF to stop yelling
on the first line of code
$ means to name the file in the control
% means end of the filename or start of NC data
the box is a character that is not supported on the palm pilot, and should not be there.
Is the character also there when the file is opened on a PC ?
examples
Code:
% ( normal un-named file )
G0G40G80G90
$ABC123.MIN% ( filename in the control when transmitted )
G0....
If you want to give a different name to a named file
--> <PIP> --> <READ> --> CN0:,456.MIN --> <WRITE> ( note the comma )( CN0 is the RS232 device channel )
CN0: can be omitted if the default device is the RS232 port
.MIN can be omitted as it also is the default extension
the 456 can be omitted as A.MIN is the default filename
so you can simply put a ,(comma)
ie
--> <PIP> --> <READ> --> , <WRITE> ( will give the new uploaded file a name of A.MIN )
A % is required at the end to terminate the transfer session, if it is missing, the file cannot be closed, and the machine may require a re-boot.
