585,997 active members*
5,217 visitors online*
    Oct 2005
    6
    Simple Calculations for a simple mind.
    So Gecko's site gives the following calculation for determining push:
    In. oz. * TPI * π / 8 = lbs of push
    According to this if I have a 380 oz-in stepper, driving a 10 tpi screw, I should achieve 1491.5 lbs of push (of course losses will result in a lower real world situation)
    380 x 10 x π / 8 (or 0.3925) = 1491.5 lbs
    Is this right? If so, I think I have been over buying steppers!
    Mar 2004
    1306
    Don't forget that this is holding torque. Look at the torque curve of the stepper and the torque falls off quite steeply with RPM.
    This of course matches nicely with the torque requirements of a typical (non HSM) machine, where you need hi toque at low speeds to cut, and little torque at high speeds for positioning.
    Regards,
    Mark
    Oct 2005
    6
    True.
    But still even at 65% of holding that comes out at 969.4 lbs of push. I expected maybe in the 300 lbs range. That should cut wood like butta.
    Mar 2004
    1306
    Are you using ballscrews (>90% efficient), or acme screws (~30%) efficient?
    But yes, NEMA23 steppers can provide a surprising amount of oomph!
    Regards,
    Mark
  1. G-simple
    By Robin Hewitt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-31-2011, 02:05 AM
  2. simple use for the cnc
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 03-07-2009, 02:49 AM
  3. Please Help!! Simple 3-D part not so simple for me
    By eaglegage in forum Mastercam
    Last Post: 05-15-2008, 04:00 PM
  4. Simple Question Simple Answer ?
    By p3t3rv in forum Stepper Motors / Drives
    Last Post: 02-16-2006, 04:00 PM
  5. Let’s keep it simple
    By CRITTERBOARDS in forum Uncategorised CAM Discussion
    Last Post: 06-19-2005, 04:33 AM
