585,668 active members*
4,564 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > New Linistepper design, PMinMO compatible, kit sale.
View Poll Results: What are the most important driver features to you?
Voters
102. You may not vote on this poll
  • Open source firmware and board layout freely available
    72 70.59%
  • Low parts-count and cost for home building
    34 33.33%
  • Low kit price to get running on a budget
    27 26.47%
  • Smooth / low resonance modes for better performance
    43 42.16%
  • Faster / more reliable operation w/ low cost surplus motors
    31 30.39%
Multiple Choice Poll.
Page 3 of 8 12345
Results 41 to 60 of 142
  1. #41
    May 2005
    1397
    technik, I would check the step pulse signal (with a scope if possible) to see if it is getting high enough. It sounds to me like it's on the harry edge of failing to be seen at the PIC and when you increase the PIC's supply, that shifts the voltage level where a signal is seen as a 1 vs a 0. You might have a PC with a "weak" parallel port (still in speck, but not driving the pins as hard as most) or a bad connection on the BOB or other connector. Also the timing setup in your CNC software may need to be adjusted so it produces a longer pulse, giving the parallel port drivers time to pull the pin to the correct level. If you find that's the issue, you can also adjust the value of the pull down resistors on the Linistepper board to adjust.
    Or it could be something totally different. I'm a software/firmware guy, not an electronics engineer at all.
  2. #42
    Oct 2005
    2392
    I just saw this, and I agree with James.
    It's very unlikely the difference between a PSU of 4.8v or 5.0v would cause any issues with the Linistepper itself.
    It could be with your parallel port. Try putting pullup resistors of 1k on the step and dir inputs (and to +5v). The parallel port is good at pulling the logic level low, but can be weak at pulling it high so the resistors may completely fix your problem.
  3. #43
    Jan 2006
    15
    Hi folks!
    Thanks a lot for your help! I tried to modify the pull-up resistors at STEP and DIR channels but without success. I measured the voltage level on the parallel port of my PC, it was around 3.3V (logical 1). I think using a 7407 buffer IC on parallel port output wires can solve the problem. I will inform you soon about the results.
  4. #44
    Jan 2006
    15
    Hi!
    Finally I have my steppers working and they are working fine. I used a CD4050 non inverting hex buffer to produce 5V at the STEP and DIR inputs of the microcontroller. During the tests I discovered that torque of the motors with the 3 boards is different. I have three PIC16F628 processors. One of them I bought a few years ago (it has different id. then the others and the motors has higher torque using this processor) and two I bought these days. I tried them all in the same LiniStepper board but the results are different. Today I will check it with scope, maybe I will see what is the problem.
    Thanks!
  5. #45
    May 2005
    1397
    Quote Originally Posted by technik View Post
    Hi!
    Thanks!
    The polarity of the full/low power line was inverted from version 1 to version 2. Try changing that line while the newer chips are installed.
  6. #46
    Jan 2006
    15
    Quote Originally Posted by James Newton View Post
    Do you mean I should connect the dip switch to GND instead of +5V?
  7. #47
    May 2005
    1397
    Not the entire DIP, no... that would affect all the lines controlled by the DIP switch... Just change the setting for the low power aka enable line. Just that one pin.
  8. #48
    Jan 2006
    15
    OK, I changed ENABLE line to high, now the motors has the same torque. But why only the newer chips requires high state of the ENABLE line? What is the difference between old and new PIC16F628? The firmware is the same for all controllers...
  9. #49
    May 2005
    1397
    The firmware is different from V1 to V2. The enable line polarity was changed to be more compatible with the PMinMO standard connector which the V2 PCB supports. This allows one break out board to be used with many different drivers such as the Linistepper, SLAm, and others at the PMinMO site.
  10. #50
    Jan 2006
    15
    Thank you for the quick reply James. I have three V2 LiniStepper drivers and V2 firmware for all of them. The only difference is the PIC16F628 revision number. So I can't understand, why the full power can be reached by ENABLE high in one case (rev number) and by ENABLE low in other case(rev number).
  11. #51
    May 2005
    1397
    I honestly have no idea.
  12. #52
    Apr 2010
    32
    Any one post a complete,linistepper ver 2,pCB,hex
  13. #53
    Apr 2010
    32
    Slightly modified Sam Waters V2 eagle files. Some minor modifications was added. Built and tested with PIC16F628-20/P.
    thanks
  14. #54
    Apr 2010
    32
    Thanks ????
  15. #55
    Apr 2010
    32
    do you have db25 interface board...with ne555 ...send me a PCB ,and schematic.. eagles files..
    OR USB INTERFACE BOARD with PIC.. send me hex and schematic eagle file.. thanks
    I will connect the linistepper.. ver 2
  16. #56
    May 2006
    25
    complete stepper driver
    I've been working on putting togeter a complete stepper driver for use with 1 to 4 modified linistepper boards(not pminmo compatible)..
    The breakout board is fully buffered on all the outputs and all the inputs and should be easy to modify for pminmo connectors.
    See what you think about it..
    This is still a work in progress and I havn't built one yet so....
    Attached Files Attached Files
  17. #57
    May 2005
    1397
    Sam, I don't suppose you could post a screen shot of the schematic for those of us who don't wish to install Eagle.
  18. #58
    Mar 2005
    523
    hello
    i don't use eagle either.
    a screen shot or pdf would be nice
    thanks
  19. #59
    May 2006
    25
    Here are the PDF's
    Quote Originally Posted by smarbaga View Post
    hello
    thanks
    I saved them as pdf files
  20. #60
    May 2005
    1397
    Hey Sam, Looks ok to me...
    Curious what led you to those MAB6H connectors? No concern, I just wondered...
    I would not use the SIL connectors as the cables are expensive. Ribbon / IDC is so much cheaper and works just fine. But if that's what you have/like so be it.
    You might want to add some extra holes for additional power resistors... it's difficult to tune for more or less amps with only one resistors.
    I've never been terribly impressed with buffered parallel port boards... if they aren't optically isolated, they aren't going to stop a spike killing the computer, and the vast majority of PC parallel ports work just fine... it's not like they have to drive much of a load. But some people swear by them, so who am I to say otherwise?
    Your BOB looks ok to me. No obvious problems. Once you have a chance to build and test, would you like me to post these to the Linistepper web page?
Page 3 of 8 12345
  1. New design and the promotion sale on lasers
    By EXLASer in forum Commercial Laser
    Last Post: 12-06-2013, 02:40 AM
  2. troubleshooting POSIX design linistepper
    By megeshg in forum Stepper Motors / Drives
    Last Post: 10-15-2012, 07:03 PM
  3. Pminmo electronics
    By SCHootie in forum Open Source CNC Machine Designs
    Last Post: 02-23-2007, 04:40 PM
  4. Questions for pminmo
    By dfro in forum CNC Machine Related Electronics
    Last Post: 07-02-2006, 04:14 AM
