584,826 active members*
5,225 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > New Linistepper design, PMinMO compatible, kit sale.
View Poll Results: What are the most important driver features to you?
Voters
102. You may not vote on this poll
  • Open source firmware and board layout freely available
    72 70.59%
  • Low parts-count and cost for home building
    34 33.33%
  • Low kit price to get running on a budget
    27 26.47%
  • Smooth / low resonance modes for better performance
    43 42.16%
  • Faster / more reliable operation w/ low cost surplus motors
    31 30.39%
Multiple Choice Poll.
Page 4 of 8 23456
Results 61 to 80 of 142
  1. #61
    Apr 2010
    32
    sO NICE BUFFER INTERFACE BOARD,DO U THINK IT'S WORKING WITH LINISTEPPER VER 2
    tHE SCHEMATIC DIAGRAM , it's nice but you should label,
    schemitt triger is for home limit switch,can you show the wiring for this interface board from switch to board and for buffer also show the step,dir,did you put enable ,mybe there's motor enable i've seen ,pin 14 is connected somewhere..
    if i get this , i will covert it to my
    own connection ,it's better to used terminal block Wago..
    what's is for resistor value ..and others
    anyone share the more easies,
    Where is the original schematic diagram or other Most clear
  2. #62
    May 2006
    25
    work in progress..
    Quote Originally Posted by levon18lopez View Post
    yes I really should... it's a work in progress..
    [quote=levon18lopez;906770]schemitt triger is for home limit switch,can you show the wiring for this interface board from switch to board[QUOTE]
    switches can be hooded up many differnt ways...
    I have 3 home switches only, connected to pins 10, 11 , 12 of the parellel port, one for each axis. Each switch is conected to ground(pin 6 of IN connector) and the other end of the switchs to (1, 2, and 3 of the IN connector)
    On the X,Y,Z,W connectors on the BOB board pin 3 is DIR, and pin 4 is STEP
    The enable is on pin 1 of the X,YZ,W connectors it can be connected to ground by connecting jumper beween pins 1 and 2 of SV1, or by putting jumper between pins 2 and 3 of SV1 you can have the software control it by changing the state of pin 17 of the parallel port.
    ---- oops---- connecting pins 1 and 2 of SV1 will have no effect as the schematic is !!!.
    Pin 1 of SV1 should be connected to 5v in the schematic not to ground... I will change that in future updates..
    R1-R5 I'm going to use 1K resistors but anything between 1K to 100K should work..
    Caps are .1 mfd for the ones by the power pins of the IC's.
    C7 should be about 470mfd at a higher voltage than you plan to use for your motors.
    C5 100mfd at 25 volts or so..
    C6 10mfd at 16 volts
    C4 .1 mfd
  3. #63
    May 2006
    25
    more info
    Quote Originally Posted by James Newton View Post
    Hey Sam, Looks ok to me...
    Curious what led you to those MAB6H connectors? No concern, I just wondered...
    I already am using them on my current setup so I just thought I would stick with them as they see to be working OK.
    I'll attach a couple of pics of my current setup.
    I would not use the SIL connectors as the cables are expensive. Ribbon / IDC is so much cheaper and works just fine. But if that's what you have/like so be it.
    I'm not planning to use cables... I designed the stepper boards so they would connect direcly to the BOB board at a 90 degree angle..
    You might want to add some extra holes for additional power resistors... it's difficult to tune for more or less amps with only one resistors.
    Ya can do that before I upload new version.
    I've never been terribly impressed with buffered parallel port boards... if they aren't optically isolated, they aren't going to stop a spike killing the computer, and the vast majority of PC parallel ports work just fine... it's not like they have to drive much of a load. But some people swear by them, so who am I to say otherwise?
    I havn't needed them yet either but didn't think it would hurt..
    The schmidt inputs I thought would be nice for noisy(electrically noisy that is) enviroments..
    Your BOB looks ok to me. No obvious problems. Once you have a chance to build and test, would you like me to post these to the Linistepper web page?
    You can post it if you like.. I'm just doing it for my own sake so...
  4. #64
    Feb 2011
    Quote Originally Posted by technik View Post
    Hi!
    Here is. Works well for PIC16F628-20/P at 16MHz.
    I'd like to build Sam Waters version of Linistepper, but I need its bill of materials, can I have it?
  5. #65
    Feb 2011
    HELP!
    Does Linistepper V2 of Mr. S. Waters work with this ( 5axis - PMinMO.com ) PMinMO interface board? Can I Have bill of materials of this linistepper version?
  6. #66
    May 2006
    25
    Did some modifications
    Here are the new files with the modifications I mentioned.
    Attached Files Attached Files
  7. #67
    May 2005
    1397
    Quote Originally Posted by doctorV View Post
    The connectors Sam is using are completely different.
  8. #68
    Feb 2011
    Misunderstanding
    I'm talking about this
  9. #69
    Feb 2011
    LINISTEPPER BUILT
    These are linistepper diriver, interface board and PIC microchip programmer microJDM (uJDM) I built. My questions are:
    1) I used PIC 16F628-041P instead of PIC 16F628A. Will it work?
    2) What's the correct stepper motor wiring for the linistepper version I built? I'm using a 5 wire stepper motor taken from an old printer.
    3)What's the correct software configuration for my interface board and driver?
    I need configurations for Linux EMC2, and KCAM and Mach3 under WinXP.
    All pictures you need are posted below.
    PS: Could you post screenshots of correct hardware and software configurations?
    Attached Thumbnails Attached Thumbnails 070320111065.jpg   110320111070.jpg   120320111091.jpg   linistepper v2_SS_sch.jpg
  10. #70
    May 2005
    1397
    No idea... probably.
    That depends on the motor. You have no info on the motor wiring? No part number on the motor? If not, this page may help you finger it out:
    techref.massmind.org/techref/io/stepper/wires.htm
    techref.massmind.org/techref/io/stepper/linistep/mach3.htm Mach3
    techref.massmind.org/techref/io/stepper/linistep/EMC.htm EMC2
    Don't have anything for KCAM... If you work it out, please let us know.
    I'm always ever so happy to be able to help.
    Nope. I don't have your motor or software (I use TurboCNC) or break out board or driver board.
  11. #71
    May 2006
    25
    If they are 16F628-04 IP then NO they are only 4 mhz, you need at least 16 mhz parts.
    If you are using V1 software make sure the enable pins are at 5 volts.
    If you are using V2 software make sure the enable pins are at 0 volts.
  12. #72
    May 2006
    25
    Hi!
    The used SW is the Eagle 3D and Povray. Here is a quick tutorial how to use it.
    Took some time to figure out how to use Eagle-3D, but I like it.
    Here are a couple of pix's of the boards I'm working on.
    Anyone know where to find a 3d file for the 3 pin resonator
    like the one in the picture?
  13. #73
    Feb 2011
    Quote Originally Posted by Sam Waters View Post
    Thanks :-D
  14. #74
    Feb 2011
    where can I order A version?
  15. #75
    Feb 2011
    By the way what is the best 16F6XX microchip for my linistepper, working with v1 or v2 software?
  16. #76
    Oct 2005
    2392
    I didn't think they made the 16F628 in 4MHz version? I thought they were all 16F628/20?
    The 16F628 will work ok provided it is the 20MHz version. The source code contains a #define already set up for 16F628. The Linisteppers were supplied with 16F628 for quite some time until the A version became more accessible. So either 16F628 or 16F628A will work ok, just check the define in the source code.
  17. #77
    May 2006
    25
    Quote Originally Posted by RomanLini View Post
    Just checked the Digikey site and they still sell the 4mhz version..
    Digi-Key - PIC16F628-04I/P-ND (Manufacturer - PIC16F628-04I/P)
  18. #78
    May 2006
    25
    Electronic Components Distributor | DigiKey Corp. | US Home Page
    or you can try ebay search for 16F628A, it came up with 144 hits when I checked today.
    These are all unprogramed IC's so you need to program them with the linistepper code..
  19. #79
    Feb 2011
    Thank you very much! :-) Today I was lucky! I just came from the (only) shop having a 16F628A. I hope my micro JDM programmer works with the chip!
    They say so: JDM2 based PIC Programmer
  20. #80
    Feb 2011
    Somebody help me
    I finally made a linistepper, and it mounts PIC 16F628A now, but stepper motor doesn't move:
    - when it's stopped, its shaft is locked
    - when it should run, the shaft vibrates.
    I tried to swap motor wires, but nothing changed, so I acquired some data by an oscilloscope. I burned LinistepperV2.hex on the microchip. The stepper motor is a NMB (minebea electronics) PM35S-048_HPL2 from an HP printer, an the software is KCAM . The beheaviour of linistepper is the same with PIC 16F628-04/P. I tested linistepper with PICs programmed and empty: the result is the same.
    Last three pictures are signals from the interface board (PMinMO 5 axis).
    What is the problem of my linistepper?
    PS: The pic programmer I used is uJDM (microJDM).
    Attached Thumbnails Attached Thumbnails A+A-step.JPG   A+B+step.JPG   stopped.JPG   enable.JPG
Page 4 of 8 23456
  1. New design and the promotion sale on lasers
    By EXLASer in forum Commercial Laser
    Last Post: 12-06-2013, 02:40 AM
  2. troubleshooting POSIX design linistepper
    By megeshg in forum Stepper Motors / Drives
    Last Post: 10-15-2012, 07:03 PM
  3. Pminmo electronics
    By SCHootie in forum Open Source CNC Machine Designs
    Last Post: 02-23-2007, 04:40 PM
  4. Questions for pminmo
    By dfro in forum CNC Machine Related Electronics
    Last Post: 07-02-2006, 04:14 AM
