585,729 active members*
4,900 visitors online*
Results 1 to 6 of 6
    Oct 2007
    187
    New Profili Software
    Hello Anyone,
    there is a new version (2.24) of Profili software with a specific function to directly cut wing cores. It looks clear and simple. I am wondering if anyone has used it.
    What are your opinions?
    Jason
    Nov 2009
    I've just started using Profili Pro 2.24.... It doesn't directly control your machine but will output dxf or dat files that can be used with GMFC or Foamworks to cut foam. It has a 3D foam cutting simulator built in and a nice database of airfoils available. Lots of options but you will need to register it to use the print or file export functions.
    Oct 2007
    187
    Thanks for clarifying that. I was understanding it directly controlled the CNC itself.
    Jason
    Mar 2010
    Export files to FoamWorks
    I have Profili Pro and my flying buddy has a CNC foam cutting table and took a couple of dat files with me but could not import them into FoamWorks. Does anyone know how to do that and could you please advise. We had to rebuild the wing planform on foam works to do the cutting. What output format from Profili will work in Foam Works
    Oct 2004
    Profili
    Have been using profili for years, only to design the wing ribs though, once ribs are saved as dxf, I use GMFC software for cutting. search for GMFC foam in google.
    Works well!
    Oct 2004
  1. About the software
    By harm in forum CNC Machining Centers
    Last Post: 11-24-2009, 02:30 PM
  2. TL1 New Software
    By redsid66 in forum Haas Lathes
    Last Post: 04-15-2009, 09:32 PM
  3. MIE Solutions - Free Quoting Software Trial Software available
    By MIE Solutions in forum News Announcements
    Last Post: 01-07-2009, 05:42 PM
  4. First post in the software dept. Free cnc software?
    By runinbymdnt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-07-2007, 04:49 AM
