585,975 active members*
4,697 visitors online*
Results 1 to 6 of 6
    Jun 2005
    8
    Fanuc OM DNC Parameter
    Just got a cheap machining center with an 0MC control but have no manuals and have never operated fanuc controls. I'm trying to change the parameters per: http://www.aggsoft.com/cnc-dnc/fanuc-0m.htm to enable DNC.
    But my machine won't let me.
    For example:
    I set PWE to 1 in DGNOS PARAM while in MDI mode
    Navigate parameter 552, type 9, then INPUT, but nothing happens.
    What am I doing wrong?
    Not sure If your control or the 0 C supports it but try a
    G10 L50;
    N552 R9;
    G11;
    in MDI
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Nov 2006
    175
    If there is a separate key switch on the operator's panel, turn it to disable and try again.
    Feb 2009
    64
    Setting 55
    On my machine DNC is enabled through the settings on number 55. Has an option for either 'ON' or 'OFF.' Some controls might have it set to be either '0' or '1.' That was all that was required to turn it on. Hitting the MDI button twice would put my control in receive mode. I use hyperterminal to send and receive.
    Jun 2005
    8
    There is a tape switch on my machine. But it doesn't look like there is anything configured to set the baud rate, stopbits, databits, or parity.
    Nov 2006
    418
    My 1990 Tape Drill machine with the 0m-C has full DNC capability, which is initiated by pressing the Remote button on the operator panel next to Memory. My Kiwa machine is the same year and control, but slightly different software version (and ladder obviously) and doesn't at this time support it?? MTB thing I'm sure.
    amurphysmu, send me a PM with your e-mail and I'll get you what I've got in documentation if it will help.
  1. Fanuc o/t parameter help
    By JimOtoole in forum Fanuc
    Last Post: 03-31-2009, 03:38 PM
  2. Need help with Fanuc 6MB parameter
    By nguyenthanhthi in forum Fanuc
    Last Post: 07-24-2008, 05:15 AM
  3. Fanuc 6t parameter #0-5 and #300-304
    By ixoxi999 in forum Fanuc
    Last Post: 12-25-2007, 02:44 AM
  4. Fanuc 3m parameter
    By salmve in forum Fanuc
    Last Post: 06-01-2007, 05:11 PM
  5. parameter fanuc om-d
    By dlmusinage in forum Fanuc
    Last Post: 05-17-2006, 10:54 PM
