585,959 active members*
4,711 visitors online*
Results 1 to 11 of 11
    Nov 2009
    4
    Exclamation 21 system error
    21 system error, no comunication between pc and nc
    after replacing battery and clearing MRJ-2 This fault came up,
    Nov 2009
    4
    Exclamation 21 system error MAZATROL 640M
    Anybody familiar with this fault??
    Jul 2007
    284
    What is the exact alarm you are getting? Is it a windows alarm or are you getting this on the alarm diagnosis screen?
    Did you replace the battery in the NC or the MR-J2? What do you mean you cleared the MR-J2? Did you reload the parameters to the MR-J2?
    Nov 2009
    4
    Quote Originally Posted by onthebumper View Post
    21 system error is always in the screen, But when I was looking around i went to the MR-J2 and as soon I get in, a message came up "PC-NC_I/F_ERROR" then down this, "[IMG]![/IMG] The read error occurred between the NC and the personal-computer. 0001" I close this message and another came up,
    "Communication error between personal computer and the servo amplifier, Check Connection."
    Then I closed this one and another window came up,
    "SPECIFICATION CHECK FOR CONNECTED MR-J2-CT"
    It can not distinguish between the Rotary Axis and the Linear Axis, For communication error. Wich do you want to connect the Rotary Axis or the Linear Axis?.
    Mar 2005
    988
    Error 21 is a software alarm and it may be because one or more of your MR-J2s lost its mind. I'd reload the MR-J2 parameters like onthebumper mentioned.
    What machine is this? and how did this all originally start?
    It's just a part..... cutter still goes round and round....
    Jul 2007
    284
    Also check the MR-J2 drives. They should be flashing some alarm on them. If they are blank or have a solid display when the NC control is on then one of the drives is bad or you have a communication problem to the drives.
    Nov 2009
    4
    21 SYSTEM ERROR
    The problem was in one of the MR-J2 drives, Someone changed a switch that is on the front of the drive, The LED screen in the front of the drive has to digitals numbers and on the right side has a switch with numbers (0 to 10) and letters (A to F), I have four drives and none of the drives can't have the same number, so two drives were using the same number(2), I have to go to the MR-J2 and check the axis settings and give them the right number. I WANT TO GIVE THANKS TO EVERY PERSON THAT TRY TO HELP ME,THANKS ALOT
    Mar 2009
    4
    Mazak 640M System Error 21
    I see you have fixed your problem.
    But just to add,
    we had the same issue, thou it was actually our Hard drive that had failed.
    take care!
    Re: Mazak 640M System Error 21
    Guys, I'm having the same issues on the Mazak integrex 300 640..Where exactly is the MJ-J2 driver located? Please help!!
    Re: 21 SYSTEM ERROR
    Hi guys, I found out one of the MRJ drives is bad, showing solid number 88. What is it mean? and how do I fix it? Do the batteries need to replace? @ MR-J2-200CT
    Any input would help, please.....
    Sep 2017
    139
    Re: 21 SYSTEM ERROR
    This is related to memory error. Try initializing the drive unit. If it doesn't work then the drive control card needs to be repaired
  1. SYSTEM BUS ERROR
    By Antonio Arguijo in forum Okuma
    Last Post: 01-14-2023, 06:19 PM
  2. 904 system error on 6M
    By kstocklin in forum Fanuc
    Last Post: 05-19-2021, 06:57 PM
  3. 6m system error
    By BrianM03 in forum Fanuc
    Last Post: 05-19-2021, 06:56 PM
  4. MV-40 SYSTEM NO. 1 ERROR
    By cowboysam777 in forum Mori Seiki Mills
    Last Post: 09-01-2010, 02:11 AM
  5. 6M System Error
    By Sailor in forum Fanuc
    Last Post: 06-01-2007, 11:56 AM
