585,902 active members*
4,016 visitors online*
    Oct 2008
    need G code programer
    I need someone that will work on by the hour to write some simple code for little parts I want to cut on my mill
    15362
    PM sent
    Mactec54
    So, you would send the drawing via email and expect the program to be sent back to you and you would do the setting up? or, Do you need the set up as well, I guess, my real question is, Do I have to be near you?
    Feb 2006
    992
    post the draw on here and ask for what you want, and I think most diffcult part is if you are demand quick turn around than I guess ...... you have to $, and I think you are better hire someone local.
    The best way to learn is trial error.
    Apr 2009
    8
    hi
    i can do some of this work if u want to mail me the parts etc,
  1. need programer, 3 axis vmc
    By chris@nwalloys in forum Employment Opportunity
    Last Post: 10-28-2009, 07:06 PM
  2. production Process programer
    By bbergman in forum Haas Mills
    Last Post: 08-11-2009, 08:47 PM
  3. cnc Programer
    By z1nonlyone in forum Employment Opportunity
    Last Post: 08-08-2008, 02:55 AM
  4. Feature CAM programer needed?
    By xcranker in forum FeatureCAM CAD/CAM
    Last Post: 05-21-2007, 12:33 PM
  5. I need a PHP programer
    By cncadmin in forum Employment Opportunity
    Last Post: 03-22-2005, 03:54 PM
