585,775 active members*
4,383 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Door interlocks ???
    Aug 2008
    4
    Door interlocks ???
    What is the best way to disconnect the door interlocks on a FADAL to avoid the external slide hold from happening ???
    Apr 2008
    1577
    I suppose it varies from year models but on all 3 of mine there is a plug in the rear cabinet that I unplugged, simple as that. Putting a sufficently strong magnet over the sensor on one of the doors is good for a temp override.
    Aug 2007
    67
    If it has the magnet switch on the top of the doors you could do like I did and remove the magnet side from the door and use plastic tie straps to hold it up against the switch side. Did mine three years ago and have not had a problem since.
    Bruce
  1. Door manufacturing
    By Jennifer in forum CNC Machining Centers
    Last Post: 01-23-2013, 04:04 PM
  2. how to override door
    By gregoryblaine in forum Hardinge Lathes
    Last Post: 09-08-2008, 09:32 PM
  3. Door Interlock
    By hatchmar in forum Fanuc
    Last Post: 12-30-2007, 01:52 AM
  4. Looking To Get Foot In Door
    By GANDY505 in forum Employment Opportunity
    Last Post: 06-05-2007, 05:28 PM
