585,557 active members*
3,366 visitors online*
Page 4 of 4 234
Results 61 to 70 of 70
  1. #61
    Jun 2003
    18
    Syntax ??
    Matt,
    Thanks for the information. Your program is really sweet! Nice work!
    Could you give me an example of the syntax to send an argument to scomm. Also, how can i tell if the port select is enable or not. I would like for scomm to just send whatever i send it and not prompt to select a port.
    What lang are you programming in? VB6 or VBnet would be my guess.
    Thanks again,
    Brian
    no problem!
  2. #62
    Apr 2003
    1876
    Quote Originally Posted by speedracer
    Matt,
    Thanks again,
    Brian
    Brian, thanks. :cheers:
    The syntax is very simple, just the program's path/name, a space, then the file to send's path/name.
    Code:
    c:\program files\scomm\scomm.exe c:\ncfiles\customer\file.ncf
    If you're always going to send from the same port, then disable "Prompt with Polling" under Options\System Settings. Doing this will launch SComm and send the file.
    I programmed it in VB6, but am considering a migration to VB.net. (So far my experience with .net has resulted in much longer load times for apps that should load very quickly.)
    If you're comfortable with computers, you can add SComm to the right mouse menu for explorer, so you can just select a file from there, right click and send it that way.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  3. #63
    May 2005
    90
    program called ATD EDIT
    http://www.atdedit.com/
    i use it for my turrent press
    i use predator DNC for my mills and lathes
  4. #64
    Apr 2003
    1876
    I've changed ISPs, here is a current link for SComm setup files.
    Current version: 3.2
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  5. #65
    Aug 2005
    9
    Matt you rock! Thanks!
  6. #66
    Apr 2003
    1876
    Quote Originally Posted by makrskr
    You're welcome.
    Let me know how it works for you. I'm always intersted in feedback, good or bad.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  7. #67
    Jul 2008
    Scomm download
    Hi all, I would like to use scomm together with my NC program library. Could you let me know where I can download scomm now? I tried links in this thread but nothing works...
    Tony
  8. #68
    Apr 2003
    1876
    Here's a copy of SComm
    http://tinyurl.com/SCOMM
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  9. #69
    Jul 2008
    Thanks, I have download it and try to install on Win2k, but inatalator always stop on MSVBVM60.dll (7 of 7) and try to install new libraries. Then restart and after starting the instalation again, I recieve the same window and again instalation of new libs and again and again...
    I tried to take files from cab and put them into separate directory and start it but I recieved some errors and program doens't start.
    Any suggestions how to make this to run?
    Tony
  10. #70
    Jun 2003
    70
    Scomm
    I just installed Scomm on XP and had no incidents. The program is nicely laid out. I am interested in incorporating comm into my Autocad abased cam program at the source code level.
    If that may be possible please sen me a private message.
    Jim
    Jim Short
    www.tahlinc.com
Page 4 of 4 234
  1. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  2. How to cut multiple parts (loop a program)
    By Bird_E in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2005, 09:16 PM
  3. feeds and speeds program
    By Kees Soeters in forum MetalWork Discussion
    Last Post: 05-12-2005, 06:32 PM
  4. A few honest questions
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-16-2004, 12:24 AM
  5. G-Code Cutter Comp Program
    By jcc3inc in forum DIY CNC Router Table Machines
    Last Post: 02-27-2004, 05:29 PM
