585,938 active members*
3,976 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > SOS / help : fanuc 15T system with "OT007 z+ overtravel (Hard) alarm" FORCE sIGNaL
Results 1 to 6 of 6
    Nov 2009
    Good Day Frieds & Expert.
    appreciate all help & advice. I have problem with fanuc 15T system with "OT007 z+ overtravel (Hard) alarm" and cannot be RESET.
    Did check all wire and overtravel switch working find. Did manually force the switch and check at PCDIagnosis bit did change 1 to 0 (on & off) X39.2 DI.
    It somethin like "internal force signal" which cause this issue. It's related to Parameter seeting?? Which parameter it's & how to resolve this problem.
    DID TRY "caN + P" aLSO NOT WORKING.
    anybody knOW how to internally disable / reset this alarm.
    is there any link to between Parameter 1000, Parameter 1005 & Parameter 1815.
    What is the correct setting for those Parameter?
    I really need urgently support since this Danichi 152 was sleep almost 3month.
    anybody can help much more appreciate.
    thx
    Faulty Z+ Hardware. Over travel switch, wiring or I/O
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Dec 2008
    239
    OT 007 +OVERTRAVEL (HARD)
    DEAR FRIEND ,
    PLEASE CHECK THE LIMIT SWITCH OF THE OTHER END [OT 007 +OVERTRAVEL (HARD) THE STROKE LIMIT SWITCH LOCATED AT THE POSITIVE SIDE WAS TURNED ON].I MEAN + SIDE OF AXIS, Also cable and 24 v supply on other side Limit sw.
    HOPE YOU CAN RUN THE MACHINE NOW.
    REGARDS
    PRABHAT MISHRA
    [email protected]
    24221
    Quote Originally Posted by yours_prabhat View Post
    PRABHAT MISHRA
    Yeah, hopefully after 2 years!!.
    Al.
    Albert E.
    Dec 2008
    239
    Al the man,
    I posted this message for update review not for JlpD so please do not mind as you are so intelligent so better to talk in a technical way.
    Regards and honor to your presence and interactivity
    Prabhat
    Be aware of this guy, he stole US$120.00 and never delivered
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Fanuc system 9 loading "hang"
    By waterfall in forum Fanuc
    Last Post: 07-26-2017, 02:03 PM
  3. Need CNC machine to cut .01" 302 full hard SS sheets (6" x 20")
    By Lowe in forum Want To Buy...Need help!
    Last Post: 03-23-2009, 06:58 PM
  4. Fanuc O-MC Alarm 405 "Z axis wrong (ZRN)"
    By JSaindon in forum Fanuc
    Last Post: 09-19-2007, 04:22 PM
  5. Fanuc 18t Turret alarm "1110"
    By senna95 in forum Fanuc
    Last Post: 10-18-2006, 05:03 PM
