585,766 active members*
4,094 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal lube and error question
    Nov 2009
    10
    I am working with a used VMC 15 we just got and when I look in the manual from Fadal it shows a lube pump, however this machine only has grease zerks.
    Some on the -X end of the table and some up by the spindle motor. Is this all that needs lubed on this machine? One other question, when I cold start the mill
    after lining up the axis marks I get "Amplifier fault axis A" as far as I know I don't have an A axis. Do I need to go into the set programing and tell it there is only XYZ?
    Thanks for all the replies on my previous post.
    Mike
    Jul 2009
    317
    Because Vmc 15's have linear ways grease is the lub system.
    Yes, Change the parameter to XYZ.
  1. Alarm (low lube,pressure) question
    By BMackinnon in forum Haas Mills
    Last Post: 05-31-2020, 12:53 PM
  2. Mazatrol T1 Excess Z error and NHead Lube
    By c5chris99 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-03-2011, 09:56 AM
  3. fadal vmc 15 spindle lube
    By timo2le in forum Fadal
    Last Post: 02-17-2009, 09:44 PM
  4. Auto Lube Setup Question
    By Chris64 in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2009, 04:27 AM
  5. Taig way Lube...Question
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 07-21-2008, 02:32 AM
