585,997 active members*
5,135 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > hurco vm1 x axis fault
Results 1 to 6 of 6
    Feb 2006
    5
    can anyone help me i have a 2year old vm1 ,i started the machine up and calibrated it ready to put in a programme and a customer came to talk to me and after about 10 mins. i heard it exhaust the air as it does if left for a period of time when i went back to work with it there was a fault on x axis showing on screen which hurco tech guy said was cable disconnected or a motor fault , this did not appear to be the case, a.nd eventually i swapped the wires over on the x and y drives and the fault stayed with the same servopack , i suspect the servopack is faulty or is there any other explanation. thanks in advance merv385
    Jun 2008
    1104
    What was the error code on the Servopack?
    Feb 2006
    5
    Quote Originally Posted by bloke View Post
    i think it was af06
    Nov 2009
    15
    Boss, even iam sailing with u in the same boat.
    In my siemens 810d controlsystem of jyoti cnc make vmc, there was x axis fault alarm;
    They snapped the x&y axes wires. the problem persisted. Then they changed the control card in the servo drive. But now my plc is not enabling. plc sign of life monitoring alarm2000 is always there. Then they found that the communication black siemens cable
    has been damaged by rat bite.Now iam waiting to replace that commn cable.yet not clear whether the problem will be solved.
    Feb 2006
    5
    not good situation when work is building up , but i cannot do anything till i get a service engineer out whenever that will be , guess i will just have to wait .
    Feb 2006
    5
    GOOD NEWS FOLKS MY VM1 IS RUNNING AGAIN IT JUST CLEARED THE FAULT ITSELF THIS EVENING , I DONT KNOW WHY BUT I AM GLAD TO SEE IT RUNNING AGAIN AND I HOPE IT KEEPS GOING.
    MERV385.
  1. C axis fault
    By Konstrukter1 in forum Fadal
    Last Post: 02-09-2020, 10:40 AM
  2. 760-22 axis drive fault
    By tstom in forum Bridgeport / Hardinge Mills
    Last Post: 01-22-2009, 03:30 AM
  3. X axis Fault
    By TR MFG in forum Fadal
    Last Post: 12-06-2007, 04:23 PM
  4. Amplifier fault on X axis.
    By Paul Petersen in forum Fadal
    Last Post: 09-06-2007, 04:43 PM
  5. C axis fault
    By Rudee in forum Fadal
    Last Post: 05-13-2005, 05:58 PM
