Hello I have a compicated issue, I use a Robodrill with a Fanuc 16i controller
and I am attempting to create a variable offset on my X axis based on data collected using a Renishaw OMP40 touch probe. The real issue is my probe stores all of the data in decimal format I.E. 1" = 1.000" and fanucs offsets using the G10L50 function uses data in the 1" = 1000 format and trying to multiply the decimal place to the right does not work. I need to know how I can force my probe to store data in the format used by the G10L50 offset.
This is how I currently load my offsets
If I needed and offset of: 1" on X, 2" on Y, and 3" on Z
and I want to add a second varable on X for the adjustment I need
#101 = 1000
#102 = 2000
#103 = 3000
G10L50
N1221 P1 R[#101]
N1221 P2 R[#102]
N1221 P3 R[#103]
G11
G54
Here is what I want to do add a variable on X for the adjustment I need
based on info collected by my probe on actual part length vs model length, and this is not scaling just an offset.
#101 = 1000
#102 = 2000
#103 = 3000
G10L50
N1221 P1 R[#101 + #572]
N1221 P2 R[#102]
N1221 P3 R[#103]
G11
G54
