585,931 active members*
5,049 visitors online*
IndustryArena Forum > CAM Software > CamWorks > cutin all parts in one wood sheet.
    Nov 2009
    Hi im new in camworks and need help to take my model of a desk done in solid works to camworks, i wanna put all my parts in one MDF wood sheet, and send the to cut by the CNC all in one operation.
    Can it be done?, hot to pass all my parts.
    thanks alot for the help!
    Nov 2009
    11
    As far as I know, the easiest way to do this is make a dummy solidworks assembly. Make an assembly sketch the size of your MDF then arrange all of your parts so they fit best within the sketch (all parts on the same plane). You can then import all of your camworks features & operations from the part files and "combine operations".
    Apr 2005
    88
    Yep, what you are looking for is called "Nesting". CAMWorks does not have the ability to nest at this time. I keep bugging them to add it. We will see...
  1. RFQ-series of small sheet aluminum parts for micromouse robot
    By apache405 in forum Employment Opportunity
    Last Post: 08-25-2008, 12:07 AM
  2. Where can I find Good CNC Wood Cutting machine for Car parts size ?
    By Calico in forum DIY CNC Router Table Machines
    Last Post: 02-28-2005, 06:36 AM
  3. Where can I buy 4-5 Axis Wood CNC for making Car Parts ??
    By Calico in forum Commercial CNC Wood Routers
    Last Post: 02-28-2005, 02:21 AM
