586,005 active members*
4,833 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Macro's on a 1997 T42 CONQUEST
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Nov 2009
    27
    G-codeguy,
    Got all your different type of deep drill P913's macro options. Going to do some testing as soon as my Hardinge machine comes open. I had P9135 in program memory and yes I can switch a 1 to a 0 or 0 to 1 think you...... Just needed to know parameter ( 10 ) bit 4= 0. Thanks for your time and patiences.
    Custom Paint Man :cheers:
  2. #22
    Jul 2007
    34
    Quote Originally Posted by g-codeguy View Post
    newc, question. Did you modify the 9135 program? It doesn't match the one in our controls. If you did, then why? I've got a headache and its my first day of work since 12-23 so how about giving an old man a break and save me the trouble of figuring what the differences create in the program's execution. Thanks.
    EDIT: Although you can drill 3 times the diameter with the first peck with 9135, it cuts succeeding pecks in half the same as the 9136 program. It appears to run like the 9136 program without the advantage of the Z variable. Probably why I originally abandoned it. You can run 3 times the diameter with 9136 also.
    The only thing I did was to add the lines for the G74 functions instead of G01.
    Otherwise it is the 9135 that came with the machine. Hardinge Conquest 42.
    Sucks to get old, huh? Everything hurts and half of it don't work no more...
  3. #23
    May 2007
    1003
    Quote Originally Posted by Dwayne Foy View Post
    G-codeguy,
    Checked out your site. Nice cars!
    If you have 9135 instead of 9136, then the format I gave you won't work. Personally I would load the 9136 program listed elsewhere in this thread. 9135 does not give you the advantage of not cutting air.
    I noticed in a later post of yours that you wanted larger peck ratios than mentioned in the OP. The 9138 program allows you to specify any ratio for the first 3 pecks. If you would rather not have to type in the extra variables, you can modify all the peck ratio depths in the 9137 program.
    If you want 5 times the diameter for the first peck, change the 3 to a 5 here
    #27=#7*3
    Same thing for the #27=#7*2.25 (2nd peck) and #27=#7*1.25 (3rd peck)
    This block #27=#7 (4th peck) would have to be changed to #27=#7*? You can't change the .5 ratio without making several more modifications to the program.
    If you are using a .125 drill and specify .25 for the minimum peck (C-value), then the program will only run the first 2 peck ratios before jumping to a loop that uses .25 for the remaining pecks (as currently written).
    If you want something changed in the subs, you can always let me know what changes you'd like. I will try to make them for you.
  4. #24
    Nov 2009
    27
    Newc,
    Sorry for not replying I have been taking care of my second business Eastcoast Refinish LLC. I have not had a chance to edit P9135 but I am going to edit my program and update your changes to see how it works. Thanks for your input.
  5. #25
    Nov 2009
    27
    Talking
    G-codeguy,
    Here is the P9135 that is in my OT control.
    :9135(DEEP DRILL)
    IF[#2LE0]GOTO6
    GOTO7
    N6#2=.05
    N7Z#5
    #23=-[3*ABS[#11]]
    IF[#5LT0]GOTO8
    GOTO9
    N8#23=-[3*ABS[#11]+ABS[#5]]
    N9IF[#23LE#6]GOTO5
    #21=-[3*ABS[#11]]
    IF[#5LT0]GOTO3
    GOTO2
    N1#21=[#21*.5]
    IF[ABS[#21]LTABS[#3]]GOTO10
    GOTO11
    N10#21=-ABS[#3]
    N11#23=[#23+#21]
    IF[#23LE#6]GOTO4
    N2Z[#8+ABS[#2]]
    N3G1G99Z#23F#9
    #8=#23
    G0Z#5
    G4X#1
    GOTO1
    N4Z[#8+ABS[#2]]
    N5G1G99Z#6F#9
    G0Z#5
    M99
    Custom Paint Man :wave:
  6. #26
    Sep 2010
    196
    I know this is an old thread, but asking about macros other than deep drilling seemed appropriate here given the title. My 1997 Conquest T42 with 18TB control has only canned routines for turning pockets, not facing them. Did Hardinge ever publish a macro (or has anyone ever made one) similar to the G70/71, but for facing?
    Torin...
Page 2 of 2 12
  1. macro's how to
    By [email protected] in forum Mach Wizards, Macros, & Addons
    Last Post: 09-03-2008, 04:07 AM
  2. macro's for probing?
    By REVCAM_Bob in forum G-Code Programing
    Last Post: 06-10-2008, 02:17 AM
  3. Macro's on Fanuc OT
    By pinguS in forum Fanuc
    Last Post: 09-23-2006, 10:51 PM
  4. macro's
    By Traceycnc300 in forum Haas Mills
    Last Post: 04-17-2006, 06:43 PM
  5. How to use Macro's
    By smallplanes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-10-2005, 10:32 AM
