585,708 active members*
3,674 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Macro's on a 1997 T42 CONQUEST
Page 1 of 2 12
Results 1 to 20 of 26
    Nov 2009
    27
    I have a 1997 T42 Conquest Hardinge turning center OT Control . I use Macro's & Var. on my Okuma turning centers but havn't used them on the Hardinge. Is the Macro's on the Hardinge a turn on parameter or will they work now! I bought this machine used in 1998 and have not had Fanuc to turn anything on. Question # two does anyone have a " Deep Drilling Macro" that can but adjusted to drill as program. ( Something like 1st depth 3x dia. , 2nd depth
    2-1/2 to 2 x dia. , third depth 1-1/2 to 1 x dia. ...on & on... ).
    May 2007
    1003
    It is a turn on option. Maybe yours came already enabled. Have you checked yet? The OT control is a bit awkward for Macro B programming. There is no equal or bracket signs on the control panel. Any modification requiring changes using either must be done off-line and the program reloaded.
    Also this control does not accept a THEN statement. So far I have been able to find other ways of accomplishing what a simple THEN would do by programming a few extra blocks.
    I wrote a simple little macro subroutine that figures depth of cut (plus sets one of two feedrates specified in the macro call based on DOC) that I use in the G71 roughng cycle. This allows me to write one program instead of many for the same part. Can't use it on the OT control. This control will not accept the use of brackets inside the G71. Nor will it allow something as simple as #100=#520+.1093 inside the G71 cycle.
    However you can use something like U#500Z-.785 or G1 Z-#500, etc. inside the G71. The OT will accept the use of brackets, etc. as long as it isn't inside the canned cycle.
    EDIT. The drill cycle you mentioned sounds interesting, but I don't know of such an animal. However, I feel certain it could be written if you wanted one bad enough.
    Dec 2009
    at main program
    N2(DRILL OPERATION - HSS 1/2 DIA )
    G0T0202G97S850M3
    G40X0.Z.1T0202
    G65P9136K-2.B.02F.01W.5C.2A.5
    G0X2.Z2.
    T0200
    M1
    :9136(DEEP DRILL)
    IF[#6GE0]GOTO70
    G00W0.
    #4=#5002
    #3=ABS[#3]
    #2=ABS[#2]
    IF[#19EQ98]GOTO1
    #19=99
    N1G#19F#9
    #27=ABS[#23]
    #28=ABS[#6]-ABS[#26]
    #29=ABS[#26]
    DO1
    IF[#27LE#3]GOTO2
    GOTO3
    N2#27=#3
    N3IF[#27GE#28]GOTO4
    G00Z[#2-#29]
    G1Z-[#29+#27]
    G00Z#4
    G4U#1
    #28=#28-#27
    #29=#29+#27
    #27=#27*.5
    END1
    N4G00Z[#2-#29]
    G1Z#6F#9
    G00Z#4
    M99
    N70#3000=1(K MUST BE NEGATIVE)
    May 2007
    1003
    9136 is Hardinge's standard Deep Drill Cycle. It does not do what Dwayne was asking. It cuts the W-value in half, then cuts that value in half, etc., until C-value is reached. The last peck can be any figure less than C-value. Of course, that would be true with the cycle Dwayne is asking for.
    Nov 2009
    27
    Cncweblangthang,
    Thanks for your reply." Believe it or not" I notice that 9136 is in my program library I have not been able to edit 9136 or is that something that Hardinge has a lock on ? I guess if I use G65P9136K-2.B.02F.01W.5C.2A.5 I don't need to edit macro list. I have been in the machining business sense 1979 and my thoughts are on drilling are 1st entirely 3 to 5 times the dia. 2nd. entirely 3-1/2 to 2-1/2 times the dia. 3rd. entirely 2-1/2 to 1-1/2 the dia. and so on depending on drill type and matl: I have not understood why cnc drilling cycles are not setup that way.
    Dwayne Foy
    May 2007
    1003
    9000 series programs are protected by default when the lathe was purchased. Most people keep the protection turned on. Change parameter 10.4 to 0 if you want to edit the 9136 program.
    In your example, P9136 will drill .5 deep, .25, .2 (6 times), and .05 on the last peck. I agree that the program cuts down on peck depths too quickly for many materials. However, in my experience this cycle can be made to work in any material although it may not be the fastest on all occasions because of the depth of the pecks.
    I was going to ask if you would like me to try making a macro program that will run the way you have described, but assume you can do it yourself with that much experience. I've only been programming lathes since 1985 which is also when I got into the business. I came from a sheet metal shop before that.
    Nov 2009
    27
    G-codeguy,
    Thanks for your reply." Yes Go For It " build me a Macro that is adjustable on peck depths. Don't have any experience with Fanuc Macro's and it's rules. We have mostly Okuma equipment expect some horizonal & vertical mills and the one Conquest T42.
    Custom Paint Man
    May 2007
    1003
    I would like to give it a try. Plant is closed until the 4th, so even if I can write it before then, I wouldn't post the program until I had a chance to test it for errors.
    In the meantime why don't you try using the 9136 program in the control. These are the variable descriptions for cncweblangthang's example in case you don't have a Hardinge manual.
    G40X0.Z.1T0202
    K= final drill depth
    B= amount where it rapids to from the previous peck (or from the material for the first peck) before it starts feeding
    F= feedrate...natch
    W= amount of 1st peck
    C= minimum peck (until the last one)
    A= dwell at retract position
    Not shown in the example is
    Z= position where the cycle will start drilling from. Z0 is the default. However, if you previously drilled a bigger hole .375 deep (or was running a casting with a .375 deep counter bore), then this would be your block call:
    G65P9136K-2.B.02F.01W.5C.2A.5Z-.375
    The drill would rapid to Z-.355 before feeding. Useful.
    Not shown or mentioned in any Hardinge manual I've looked at (at least I can't recall seeing any mention of it) is the fact that you can program it for IPM if desired. You can see that from the P9136 program. #19 (S) controls IPM/IPR with IPR being the default. Live tooling is the ONLY time I would select IPM.
    SO
    G65P9136K-2.B.02F.01W.5C.2A.5S98.
    would run the drill in IPM.
    Although I agree that cutting the 2nd peck in half from the 1st peck amount is often too much of a cut in pecking depth, I don't believe in running 3x the drill diameter on the 1st peck for all drills or all materials. A .5 inch drill would go 1.5 inches deep before pecking. A standard drill would burn up on the first part in most of the materials we run unless running WAY to slow. YMMV.
    EDIT. I can give you an example of how I program the Hardinges if interested. It saves some typing and memory space. It also requires making a couple changes in the parameters. Are the Safe Index subprograms still in your control?
    EDIT #2. BTW, just for your own knowledge, I think you will find that you don't have a Conquest T42 but a Conquest 42. I believe Hardinge told me if an OT control is used it is a Conquest 42. If an 18T control is used, it is a T42. Apparently they use those model designations for determining which control is on the lathe. Someone will correct me if my memory is faulty.
    Nov 2009
    27
    G-codeguy,
    Thanks for your reply. I will try to use G65P9136K-2.B.02F.01W.5C.2A.5 in the mean time. That Z-.375 is a good little code to keep from cutting air.
    Custom Paint Man :cheers:
    May 2007
    1003
    Mr. Foy, I have your subroutine done tho not tested yet. Before I get into that I wanted to mention another option I thought of while writing your program.
    You could slightly modify the existing 9136 program in your control. Replace the W representing the first peck depth with a D representing the drill diameter.
    Replace #27=ABS[#23] with #27=ABS[#7]*3 and
    Replace #27=#27*.5 with #27=#27*.75
    This would drill 3 times the diameter, then 2.25 times diameter, then 1.6875, 1.2656 (rounded), .9492 (rounded), etc. until C (minimum peck) has been reached. Of course you could make the 3 and/or .75 a variable for even more control.
    Regarding the program I wrote. First let me mention that it is 2 pages longer than the Hardinge subroutine. That is because their program uses a constant. I used 3x, 2.25x, 1.25x 1x and then .5x for a low limit. These figures basically fall within the mean of the ratios you mentioned in your original post except for .5. I had to set a limit somewhere. Whether or not the program actually will use them all depends on drill diameter, drill depth and the minimum peck specified.
    Naturally you could modify any of these values before loading the program....or....consider this. I plan on making a second program by modifying this subroutine. It will require adding 4 more definitions to the G65 call block, but will allow you to individually specify the diameter ratio for the first 4 pecks. Provided, of course, that the hole is deep enough in relation to the drill diameter to use all 4 as a minimum number of pecks.
    I will test the subroutine as soon as I can after we go back to work Monday. I'll let you know the results then.
    Nov 2009
    27
    G-codeguy
    What was the system parameter to be able to edit P9136 ? "Oh By The Way " the reason my logo is Custom Paint Man I have a custom paint and body shop I started 15 years ago. Check out my website eastcoastrefinish.com and see some of my work.
    Custom Paint Man :wave:
    May 2007
    1003
    I mentioned it in a previous post, but here it is again. Change parameter 10.4 to 0 if you want to edit the 9136 program. Do you know how to change a parameter on the Hardinge? Just asking. No offense meant. It's easy to ass-u-me too much.
    I tested the program on a 21i-T control this morning. Neither of the lathes with an OT control are going to be open for some time. Worked fine. Shouldn't get any different results on an OT.
    I will send the program in a PM. Should fit if I don't do a lot of explaining. It drills at the ratios I've already mentioned. Also as previously mentioned, you can change 3 values in the subprogram and add 3 variables to the G65 call to vary the ratios of the first 3 pecks (or all 5 of the first 5 pecks if you want to add 2 more variables).
    I will make the modifications and send the modified program in a separate PM. Experiment away. Then let me (and others if they'd like to know) what ratios work the best for you in various materials.
    I've tried to allow for all circumstances. From tiny drills to the huge, from brass to the toughest materials.
    Jul 2007
    34
    Hardinge also wrote a nifty macro - 9135 - that will drill to a depth of 3x dia and then decrement depth until it locks on a minimum depth increment. They also have a G74 chip breaking routine, but that has no pullouts. My 9134 combines the deep hole pullout routine with the G74 chip breaker.
    Where:
    J = Z axis start position
    K = Z axis end position
    B = Start feed increment value (buffer distance to where drill left off)
    F = Feedrate
    H = Drill dia. (you can lie, to get more or less depth on first increments)
    C = Minimum increment
    A = Dwell at retract point (I seldom use this)
    Programs follow - call with G65 :
    O9135 (DEEP DRILL - NO CHIP BREAK)
    IF[#2LE0]GOTO6
    GOTO7
    N6#2=.05
    N7Z#5
    #23=-[3*ABS[#11]]
    IF[#5LT0]GOTO8
    GOTO9
    N8#23=-[3*ABS[#11]+ABS[#5]]
    N9IF[#23LE#6]GOTO5
    #21=-[3*ABS[#11]]
    IF[#5LT0]GOTO3
    GOTO2
    N1#21=[#21*.5]
    IF[ABS[#21]LTABS[#3]]GOTO10
    GOTO11
    N10#21=-ABS[#3]
    N11#23=[#23+#21]
    IF[#23LE#6]GOTO4
    N2Z[#8+ABS[#2]]
    N3G1G99Z#23F#9
    #8=#23
    G0Z#5
    G4X#1
    GOTO1
    N4Z[#8+ABS[#2]]
    N5G1G99Z#6F#9
    G0Z#5
    M99
    O9134 (DEEP DRILL - CHIP BREAK)
    IF[#2LE0]GOTO6
    GOTO7
    N6#2=.05
    N7Z#5
    #8=#5
    #23=-[3*ABS[#11]]
    IF[#5LT0]GOTO8
    GOTO9
    N9IF[#23LE#6]GOTO5
    #21=-[3*ABS[#11]]
    IF[#5LT0]GOTO3
    GOTO2
    N1#21=[#21*.5]
    GOTO11
    N10#21=-ABS[#3]
    N11#23=[#23+#21]
    IF[#23LE#6]GOTO4
    N2Z[#8+ABS[#2]]
    N3G99
    G74R0.015
    G74Z#23Q0900F#9
    #8=#23
    G0Z#5
    G4X#1
    GOTO1
    N4Z[#8+ABS[#2]]
    N5G99
    G74R0.015
    G74Q0900Z#6F#9
    G0Z#5
    M99
    Regards,
    newc
    May 2007
    1003
    Thanks, newc. I quit using the 9135 program once we got the newer lathes which had the 9136 deep drill cycle. Nor have I looked at the 9135 program since I taught myself Macro B programming. Looks like I will need to take a few minutes to study it. Might want to start using it again. I ran it exactly like you suggested...by modifying the H value to get the first peck depth I wanted.
    Also a coincidence is that I also have a 9134 drilling program. Except mine is a little more involved. We use insert drills, spade drills, carbide drills (of at least 3 grades) and HSS drills. The operator changes a variable to specify the type of drill being used. If carbide drill, he changes another variable to match the grade.
    I set the tool station and drill diameter with variables (in main program, of course). Both can be changed by the operator. I also set such things as SFM/feedrate for the various carbide drills and cut-off position (or final c-o position if making multiple parts). Again, all can be changed by the operator if necessary. I let 9134 figure the RPM, how deep to drill, how to drill...one shot or peck (I've incorporated the 9136 and G74 cycles in it), etc.
    My G65 for an insert drill or spade drill looks like this
    G65P9134S600F.0035
    while an HSS drill might look like this
    G65P9134W.55B.02C.25A.2F.005S65V135.
    V being the drill angle. You can use included angle or measure one side on a comparator and use that.
    Aren't macros fun!!!
    Jul 2007
    34
    Macros are certainly fun, what with nested loops and levels of calls, but the one thing that is hard to keep in mind - customers don't pay for pretty programs, they want parts. Sometimes you get so hung up writing the perfect routine you forget to keep your eye on the ball!!
    May 2007
    1003
    Mr. Foy. I included the option for a dwell at the bottom of the drill. I almost never use a dwell here on the Hardinge lathes. However I had to add a dwell at the bottom for the Daewoos. Even tho I have the exact stop M-code in my safe index routines, it doesn't work on the Daewoos. I was having problems with uncoated carbide drills chipping on the cutting edge. I eliminated the problem by add this dwell before retracting.
    Takes too long to figure dwell in seconds each time. Then if you change the RPM, you've got to refigure the dwell. So the dwell option I included uses revolutions. The sub figures the seconds. So if you want to dwell for 2 revolutions at the bottom before retracting, you would include T2 in the G65 call.
    May 2007
    1003
    Quote Originally Posted by newc View Post
    Obviously I wouldn't let a machine sit idle while I worked on a macro. Not that there hasn't been times when a lathe had to wait for a program from me. I program for approximately 20 lathes plus help with setups on occasion. End of last year we had a 2 week period where I was getting all new jobs of 25-35 pieces (double that number for end washers). Luckily I wasn't asked to set up during that time, or more than one probably would have been sitting. I was able to keep ahead, tho.
    May 2007
    1003
    newc, question. Did you modify the 9135 program? It doesn't match the one in our controls. If you did, then why? I've got a headache and its my first day of work since 12-23 so how about giving an old man a break and save me the trouble of figuring what the differences create in the program's execution. Thanks.
    EDIT: Although you can drill 3 times the diameter with the first peck with 9135, it cuts succeeding pecks in half the same as the 9136 program. It appears to run like the 9136 program without the advantage of the Z variable. Probably why I originally abandoned it. You can run 3 times the diameter with 9136 also.
    Jul 2007
    34
    Quote Originally Posted by g-codeguy View Post
    Your fingers must have been a blur - lol.
    May 2007
    1003
    Well, not every machine was running that quantity of parts, or I probably would have had a heart attack. Some lathes were running old jobs, but...yeah...I was busy. Think I lost my fingerprints. LOL.
Page 1 of 2 12
  1. macro's how to
    By [email protected] in forum Mach Wizards, Macros, & Addons
    Last Post: 09-03-2008, 04:07 AM
  2. macro's for probing?
    By REVCAM_Bob in forum G-Code Programing
    Last Post: 06-10-2008, 02:17 AM
  3. Macro's on Fanuc OT
    By pinguS in forum Fanuc
    Last Post: 09-23-2006, 10:51 PM
  4. macro's
    By Traceycnc300 in forum Haas Mills
    Last Post: 04-17-2006, 06:43 PM
  5. How to use Macro's
    By smallplanes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-10-2005, 10:32 AM
