585,591 active members*
2,676 visitors online*
Page 1 of 2 12
Results 1 to 20 of 36
    Dec 2009
    Bavelloni Tech
    Hi everyone,
    I just wanted to let everyone out there know that I am an ex-Bavelloni Technician and I still know quite a bit for the machines and software, as well as being Certified by Bavelloni S.P.A. in Italy as a technician(I have the certificate if anyone wants proof). If any of you out there have any questions about the Bavelloni CNC systems (I have installed, trained, torn apart, and rebuilt every CNC that Bavelloni has out there) please drop me a line and ask your questions and I will do my best to help you out
    Zoltan
    Nov 2010
    I realized you posted this a while back. I was wondering if you could help me with technical issues ive been having with our gemiv10 glass polishing machine.Let me know if you can thanks.
    Nov 2011
    alpa
    Quote Originally Posted by Yarvin View Post
    Hi everyone,
    Zoltan
    Please help. I'm new in the forum,and if you can help me I'd appreciate.
    I have a problem with my Bav Alp a 102s. It gives me warning at the operator messages page like "SPINDLE MOTOR THERMAL PROTECTION".
    Any idea what the problem could be? I know it could be spindle cable problem but before I start desmandling I could listen to someone else who knows more than i do.Any idea or comment-suggestion is welcome.
    Zorba
    Sep 2006
    4
    Quote Originally Posted by cncforlife View Post
    Zorba
    Hi
    With typ off driver you have Intramat ore Yaskawa.
    Check the LED on the driver and the cable
    often ther is a problem with the Cable.
    RC
    Oct 2011
    HI
    I AM LOOKING FOR SOME HELP ON MY EGAR 450. IF YOU ARE INTERESTED PLEASE LET ME KNOW.
    [email protected]
    THANKS SASHA
    Sep 2006
    4
    Quote Originally Posted by SASHA-V View Post
    HI
    [email protected]
    THANKS SASHA
    Hi Sasha
    Tel me wits problem you have .
    Regards Roy
    Feb 2012
    HELP FOR AXE X AND POSMO
    Hi everyone,
    Zoltan
    Hello
    I have a problem setup and calibration due to change engine POSMO. I lost my login technician to access the setup page. In addition, the parameters of the X axis jumped and I can not make the reset of the VT-1301
    Thank you for your help
    May 2012
    Anyone out there with Bavelloni cutting tables, especially with the NUM1040 controller, experience?
    I have an issue I'm trying to work out.
    Ciao Zoltan tu sei un tecnico ex bavelloni ? Mi puoi aiutare sulla Kam 100
    Grazie
    Se si mi puoi contattare
    Jan 2015
    Re: Bavelloni Tech
    Hi everyone,
    Zoltan
    hi i need help.
    i work on bavelloni egar 450-4
    somebody at work was running the machine without me there.
    they just called me and told me that there is an error on the screen and that they cant do anything.
    the error is RUN TIME ERROR 3000
    can you please help me
    thank you
    Jan 2015
    Re: Bavelloni Tech
    hi i need help.
    thank you
    Mar 2015
    Re: Bavelloni Tech
    Have you had any luck with solving the run time error problem? I got the error this morning on my egar 323
    Aug 2015
    Re: Bavelloni Tech
    need solution( trigger axes power magaz. tool presence sensor cable broken) ????????? its bad ????
    Aug 2015
    4
    Re: Bavelloni Tech
    Hi, I'm new to operating a CNC machine and I could really use some help with an error that I'm getting on my Bavelloni Egar 450/4N. The error is "Move demanded of an un-datummed axis". I cannot use the machine because of this error. If anyone has some knowledge and experience with this please help me out. Thank you.
    Aug 2015
    4
    Re: Bavelloni Tech
    Aug 2015
    4
    Re: Bavelloni Tech
    Hi everyone,
    Zoltan
    Hi Zoltan, do you know anything about this error "Move demanded of an un-datummed axis"?
    Running a Bavelloni Egar 450/4N. I'm new to this and I cannot do anything because of this error. Please help me.
    Thank you.
    Sep 2015
    Re: Bavelloni Tech
    Hello. I'm hoping this is the right thread. I'm working on a Bavelloni Alpa 350, and I'm getting an error "C AXIS OUT POSITION". I know the C Axis is the spindle rotation, but how do I correct this problem? Any help would be appreciated, thank you!
    Julia
    Sep 2006
    4
    Re: Bavelloni Tech
    Quote Originally Posted by JToronto View Post
    Julia
    Hello
    I think you have a alpa 320 ore 315. the problem wil be the belt of the C axes please check this move it on manuel.
    Regards Roy
    Jul 2017
    5
    I hope every thing running well.We have a bavelloni cutting machine (REV 370 SLH - 2005) and this ERROR can be seen in some times : Arms don't put glass sheet on the correct place and puts glass ahead. At this time we should run machine manually and take back glass sheet.
    The Error number displayed on the drive for 2sec (Drive type: NS600 Yaskawa) : A.9F (E53E). I chenged NS600 card but it is remain.
    Jul 2017
    5
Page 1 of 2 12
  1. EasyCad Z. Bavelloni
    By cbieger in forum Uncategorised CAM Discussion
    Last Post: 07-29-2021, 07:06 PM
  2. Need a low tech solution to a high tech problem (kind of urgent)
    By PeliTac in forum Want To Buy...Need help!
    Last Post: 01-23-2014, 05:05 PM
  3. z Bavelloni egar 323-5n
    By KIRILL33 in forum DNC Problems and Solutions
    Last Post: 10-31-2013, 03:10 PM
  4. bavelloni
    By marktill in forum Glass, Plastic and Stone
    Last Post: 09-25-2010, 03:52 PM
  5. Bavelloni Egar320T
    By JSandSO in forum Uncategorised CAM Discussion
    Last Post: 07-13-2005, 05:19 PM
