585,883 active members*
5,827 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Mach3 users & kernel speed
    Feb 2009
    1290
    Has anyone come across this formula to calculate the minimum kernel speed you require. It seems if 40ipm cutting and 80ipm rapids are all you need then a kernel speed of 26K should do.
    If you want to calculate out your max pulse frequency start with the max velocity of your machine.
    Max_Velocity(IPM) * Steps/Unit = max_step_min (a.k.a. #steps in one minute at max velocity)
    max_step_min / 60 = max_pulse_frequency
    Your kernel frequency needs to the the lowest choice you have that is greater than your max_pulse_frequency.
    Quote Originally Posted by Drools View Post
    Depends on your steps unit. If it's really high, then you may need a higher kernel speed.
    I use 25Khz and have 175ipm rapids. Max is about 220-230 with 6400 steps/unit.
  1. Kernel Speed
    By CARLES in forum Mach Plasma / Laser
    Last Post: 03-23-2011, 03:12 PM
  2. How To Know What Kernel Speed To Use?
    By Brenck in forum Mach Software (ArtSoft software)
    Last Post: 10-20-2009, 05:04 AM
  3. Kernel Speed?
    By bundypro in forum Machines running Mach Software
    Last Post: 01-15-2009, 04:44 PM
  4. EMC2 on Ubuntu Studio 8.04.1, kernel 2.6.24-19-rt
    By dfro in forum LinuxCNC (formerly EMC2)
    Last Post: 09-03-2008, 04:28 PM
  5. Difference in Kernel Speeds?
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 04-28-2007, 10:24 PM
