585,883 active members*
5,071 visitors online*
Results 1 to 9 of 9
    Nov 2009
    53
    Unhappy Fanuc 11T bootup problem
    I have a Mazak SL80 with a 11Ta control. After it is turned off for a while it will boot up to the IPL screed and have a "Load File: error" just like in the picture. I have to clear all the memory including the PC parameters and reload the options and the machine will come up and run. It will run untill I turn it off for a day or two and all this will start again. Is this a problem in the Bubble Memory or the Main Board?
    May 2009
    181
    what does the display show on the mainboard?
    Nov 2009
    41
    How about your batteries?
    If it happens when it's been powered off for a while it sounds like low volts on the batteries and the memory leaking.
    If you haven't chnaged them recently it could be prime suspect, and on our 0-M they have to be changed while the machine is powered up.
    Apr 2009
    1379
    Fanuc 6,11,12 don't use battereies for main memory- bubble memory is non-volatile. It sound like a BMU going bad. Check your power supply voltages.
    Oct 2009
    12
    hello every one
    i have mori seiki 11tt lath when i have on my machine its display canot on i but its monitor is ok please tell me about this .
    Feb 2009
    6028
    BMU
    Sounds like a bubble memory board to me to. The Fanuc replacement is no longer bubble, and has a battery. The plus side is it has a lot more memory with it. Did one last year on a mill here just for the memory increase. Think it was around 1500 dollars. not too bad.
    Nov 2009
    41
    Quote Originally Posted by Khalid.Ins-Tek View Post
    hello every one
    Khalid - Please make a new thread, this one is for Scottjit's problem.
    Nov 2009
    53
    Smile I will check it out.
    Quote Originally Posted by memoryman View Post
    Thanks for the response. I have a extra Bubble Memory card. I will check the voltage on the Power supply also. The spindle drive is out for repair and will will compete this in about two weeks.
    Nov 2009
    53
    I changed the Bubble memory same problem. Changed the base board (Main board) and the problem went away. Thanks for all the help.
  1. Fanuc Oi-TA LCD problem
    By rai in forum Fanuc
    Last Post: 01-31-2012, 01:00 PM
  2. PROBLEM ON FANUC 0GD
    By vinoth in forum Fanuc
    Last Post: 03-17-2009, 06:15 PM
  3. Fanuc new 0I problem
    By sylvain in forum European Club House
    Last Post: 12-30-2007, 06:17 PM
  4. FANUC-OM ATC Problem
    By Stebedeff in forum Fanuc
    Last Post: 07-27-2007, 04:18 PM
  5. Computer bootup hangs when connected to Breakout board
    By haysys in forum CNC Machine Related Electronics
    Last Post: 04-08-2006, 03:55 PM
