Hi
i have some experience in g-code programming but for woodworking where things are a bit easier i would say (you do not care how much material you are going to remove for example)
i was wondering what code you need to write for a machine to make a straight cut removing 10mm in total and 0.5mm each pass. is there a special g code to use in combination with the usual codes for lines and circles that automatically calculates and executes the steps needed for achieving the various passes?
thanks
