585,763 active members*
4,213 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc A16B-1200-0270 Buffer board..?
Results 1 to 14 of 14
    Oct 2007
    179
    Does anyone know what this board is..?
    A16B-1200-0270
    I bought a machine with Fanuc 6MB11 a couple of years ago and this board was attached inside the cabinet door but not connected in any way..
    I'm told it is a buffer board for drip feeding..?
    If it is I would like to connect it!
    cnc-it
    Apr 2009
    1379
    I have the description manual for that board (B-90699E/03) and have the board too, but have no actual experience using that. It can be used on the 5,6,7,9,11,12,200A/B,3000C and 2000C controls.
    Dec 2009
    15
    A16B-1200-0270
    REMOTE BUFFER FOR OLD NC
    You do need to setup parameters to run your DNC. This board has jumpers which need to be set
    correctly.
    Remote Buffer:
    INPUT DEVICE 1 = 1
    INPUT DEVICE 2 = 0
    FOR REMOTE BUFFER, you need to set communication parameters by using jumpers on the REMOTE BUFFER PCB.
    You need the manual : B-90699E/03 which has details about jumpers.
    Oct 2007
    179
    Thanks Guys I'll try and get the manual as there are no cables with mine so I will have to make some.
    I presume then that this is a Fanuc version of a BTR and replaces the tape reader..?
    Jun 2008
    43
    Buffer board A16B-1200-0270
    Quote Originally Posted by cnc-it View Post
    I have the buffer board A16B-1200-0270 too but I don't know how to set the jumper.I know this board is a Fanuc version of a BTR for DNC operation.Can any one help me set the jumper or get the manual?
    David
    Oct 2007
    179
    Hi have managed to get The Fanuc remote buffer descriptions manual B-90699E/03 . It doesn't detail how to connect the board to the Fanuc 6 motherboard. It looks like I run the tape reader ribbon cable that already goes into the motherboard from the remote buffer then connect the tape reader to the remote buffer? Just need to make sure on this before I try anything!
    John.
    Sep 2008
    67
    i want anstall a board remort bufer A16B-1200-0270 ,but i dont hav manual B-90699E/03
    if you hav send me by email : [email protected]
    thaks
    best regards
    May 2004
    402
    A16B-1200-0270
    John,
    Did you ever get the A16B-1200-0270 remote buffer working? I'm looking to put one on my Fanuc 6M ?
    I see you sourced the manual for it - was it in electronic format - if so can I be cheeky and ask for a copy to [email protected]
    I've tried pming you but your inbox is full!
    Many thanks
    Andrew
    Andrew Mawson
    East Sussex, UK
    Oct 2006
    100
    Re: Fanuc A16B-1200-0270 Buffer board..?
    Quote Originally Posted by memoryman View Post
    Do you have the manual in PDF ?
    [email protected]
    Thnak You
    Sep 2010
    125
    THIS PCB IS A TAPE READER EMULATOR WITH
    YOU HAVE TO CONNECT IT ON THE HE50 CONNECTOR OF THE TAPE READER
    SELECT RMT IN THE SETTING SCREEN
    YOU SEND BY RS232 YOUR PROGRAM AND THE COMMUNICATION SHALL STOP AT SOMETHING LIKE 4MB (BUFFER FULL )
    THEN CYCLE START
    Jun 2008
    43
    Quote Originally Posted by tmbruno28 View Post
    THEN CYCLE START
    It sound good,please tell me how to set the jumper and the comunication protocol
    David
    Quote Originally Posted by lmostafa View Post
    thaks
    best regards
    Can you share me these documemt to my mail: [email protected]
    Re: A16B-1200-0270
    Quote Originally Posted by FanucGuru View Post
    correctly.
    Remote Buffer:
    INPUT DEVICE 1 = 1
    INPUT DEVICE 2 = 0
    Dear friend.
    Can you share me " B-90699E/03 " file???
    My mail: [email protected].
    Dec 2005
    11
    Re: A16B-1200-0270
    does any one have a copy of the manual please B-90699E if so can they email me it [email protected]
  1. Fanuc A16B-1200-0800 BOARD ?
    By bbqa01 in forum Servo Motors / Drives
    Last Post: 06-13-2014, 05:26 PM
