585,768 active members*
4,103 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Changing defaults in v9
    Dec 2004
    55
    I have been streamlining my operations lately and would like some of the things to come up to my preset defaults like, I want MC to use my Haas post instead of the MPFan post all the time without me selecting it every time.. I also have made a sort of "standard tool list" for my machine. I would like to call up a 1/2 square end mill and it come up as tool 16 and the feeds and speeds, clearances and feed planes be to my settings not MC's. Is this possable? I know it is, I mean is it possable for you to enlighten me?
    Leroy
    Jun 2005
    305
    As far as changing the default post file, there are 2 ways of doing it.
    #1, AFTER saving a copy, open mill9.cfg in a text editor such as notepad, and change question #550 to the name of the post file, without the .pst extension, that you want to be the default post.
    #2, The prefered way is, AFTER saving a copy of mill9.cfg, go Screen,Configure,Files tab, in the file usage box on the right, highlight 'Post processor', then click the file open button to the right of the post file name.
    There you can select the post file you want to be the default.
    My personal rule #1 is NEVER make changes to the config file with a part file open.
    Some config settings CAN change as you are working on a part.
    It is safest to do a File,New BEFORE changing the config file.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    Dec 2004
    55
    That fixed my post, thanks. How about the tool list defaults?
    Thanks again.
    Mar 2006
    1013
    Screen - Configure - Files (tab).
    In the right side box (File Usage), select Postprocessor, click on the file cabinet next to the post name and select your file.
    Tool Library and Setup Sheet default is also in that section.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Dec 2004
    55
    Thanks for the help Matt, I own your complete set of training software for v9. I'm sorry but I still am not understanding how to make the tool numbers and associated tools with feeds and speeds the defaults. Can you be any more specific? I see the tools.tl9 file, but thats it. How do I make a new library? If I missed it in the training cds which one is it in? Thanks alot.
  1. customer defaults
    By tarponicus in forum UG NX
    Last Post: 02-05-2009, 02:01 PM
  2. Preadator 7.0 defaults
    By orizaba in forum BobCad-Cam
    Last Post: 06-06-2008, 04:38 PM
  3. Replies: 15
    Last Post: 12-27-2007, 09:02 PM
  4. Rhino_Tools_Options Defaults?
    By robinsoncr in forum Rhino 3D
    Last Post: 06-12-2006, 05:07 PM
  5. Changing CS
    By fastolds in forum GibbsCAM
    Last Post: 02-02-2005, 07:31 AM
