585,581 active members*
4,020 visitors online*
Thread: RS-232
Results 1 to 8 of 8
    Dec 2008
    39
    Question RS-232
    Hello!
    I would like to download my program file into my Fanuc 21i-T by the RS-232 port.
    Is-it possible? if yes how can i do that?
    The RS-232 pin out is it standard?
    Feb 2009
    64
    RS-232
    As long as you have a serial port on your machine and a cable to connect to your pc. You can use windows hyperterminal to send. Just start a new connection in hyperterminal and make sure all the info matches up to what is on your machine.
    Dec 2009
    15
    RE-232C
    Software Hand Shake
    DB25(PIN) DB-9 (PIN)
    SD (PIN#2) SD( PIN#3)
    RD (PIN#3) RD (PIN#2)
    SG (PIN#7) SG (PIN#5)
    JUMP (PIN #4 &5) JUMP (PIN #7 & 8)
    JUMP (PIN # 6,8 &20) JUMP (PIN # 1,4 &6)
    Control Side Settings:
    PUNCH CODE = 1 (0:EIA 1:ISO)
    I/O CHANNEL = 0 (JD5A CONNECTOR,CHANNEL 0)
    PARAMETERS
    0000 = XXXXXX10
    0100 = 00000000
    0101 = 10000001
    0102 = 0
    0103 = 10
    Feb 2009
    6028
    rs232
    Just go to radio shack and get the 9-25 pin cable, and a null modem adapter. Saves trying to make a cable if your not good at it. The parameter settings listed will work, but he didn't give the actual baud rade, parity, stop bits with it. I don't have a manual at my desk to look it up. BTW an i series can use a ATA flash card or compact flash card with an adapter. Much easier than RS232.
    May 2009
    181
    Quote Originally Posted by FanucGuru View Post
    PARAMETERS
    0000 = XXXXXX10
    0100 = 00000000
    0101 = 10000001
    0102 = 0
    0103 = 10
    you forgot to make channel 20=0
    Quote Originally Posted by underthetire View Post
    yes that is true i have one and it works.. much easier to buy it.. you are going to need a null modem adapter the 9-25 pin adapter and a gender changer.. .
    Feb 2009
    6028
    Is 10 4800 or 9600 baud?
    2932
    10 is 4800, 11 is 9600
    Dec 2009
    15
    RS232C
    I/O CHANNEL = 0 and Parameter 20 =0 means same thing.........so your parameter 20 will set itself as long as u put 0 on I/O CHANNEL.
    parameter 101 sets teh following values:
    #7 (NFD)
    0 : Feed is output when data is output.
    1 : Feed is not output when data is output.
    #3 (ASI)
    0 : EIA or ISO code is used for input/output data.
    1 : ASCII code is used.
    #0 (SB2) 0 : No. of stop bits is 1.
    1 : No. of stop bits is 2.
    I totally agree PCMCIA Adapter with compact flash hard is the best way to go if you don't have dataserver option.
    I/O CHANNEL = 4 = Parameter 20.
    Parameter: 0103 Baud Rate
    1: 50 5: 200 9: 2400
    2: 100 6: 300 10: 4800
    3: 110 7: 600 11: 9600
    4: 150 8: 1200 12: 19200 [BPS]
