585,922 active members*
3,931 visitors online*
    Oct 2007
    31
    Initial Start Up Running Mach3
    I have recently completed my cnc router table and am at the point I want to try testing each axis and to possibly run a simple program in Mach 3.
    I have downloaded the trial version of Mach 3, but do not know what the first steps are to testing or to run a test program.
    Ultimately I would like to be able to load a DXF file created in Autocad and run this in Mach 3. Here again, I am very new to the entire process.
    Kevin
    First thing you need to do is set up the ports and pins, and do the motor tuning for each axis. It'a a good idea to watch the Mach3 tutorial videos at http://www.machsupport.com/videos/
    You can use the built in Wizards to create some simple test code, or enter g-code using the MDI input.
    To use a .dxf file, you'll need to convert it to g-code using a CAM program. Mach comes with a limited version of LazyCAM. I personally do not like it, but if you want to try it, I recommend reading the manual http://www.machsupport.com/forum/ind...c,12078.0.html
    A much easier program to learn and use is Vectric's Cut2D. http://www.vectric.com/WebSite/Vectr.../c2d_index.htm
    If you have more specific questions, feel free to ask.
    Oct 2007
    31
    Thank you for the suggestions. I will watch the tutorials.
    I had heard that Lazy CAM was difficult to use, I will take a look at Vetric.
    Thanks again
    Kevin
    Oct 2007
    31
    Thanks again for the suggestion. I found the tutorials VERY helpful. I now have the motors spinning and running good.
    Thanks again! :cheers:
    Ferrari2007
  1. Running Mach3 on a little Acer One
    By felixthecat728 in forum Machines running Mach Software
    Last Post: 01-09-2010, 05:57 PM
  2. CHNC II GN10 control Initial start up problem
    By LeftCoastCNC in forum Hardinge Lathes
    Last Post: 07-14-2009, 04:00 AM
  3. Running Mach3 with only X&Y Axis
    By kae in forum Mach Mill
    Last Post: 12-31-2008, 11:21 PM
  4. running mach3
    By woodman08 in forum Machines running Mach Software
    Last Post: 02-26-2008, 05:21 PM
  5. Laptops Running Mach3?
    By Fred Kelly in forum Shopmaster/Shoptask
    Last Post: 09-10-2007, 02:07 PM
