Hi there,
I am planning on getting a Taig and refitting it into an EDM mill (not an EDM wire or sinker machine, really a mill: the EDM tool will be rotating just like a regular cutter, and probably held in a normal collet). I have designed my own circuit for this (for the high-voltage part of it anyway) which works quite well in a breadboard version already.
The tricky part... the software driving this needs to be EDM-aware, so the speed at which it moves the tool will be "as fast as material is removed", not any specified speed To accomplish this the EDM circuitry would detect the rate of material removal and coordinate speed with whatever software is driving the XYZ axes. I will probably write a patched version of EMC first. Beyond that, if this takes off, maybe the Mach3 folks can put in some support for it in their software. Bottom line, you won't be able to use arbitrary CNC software with this, but the most popular options should be supported.
Also of course this will be quite slow... the volumetric material removal rate will be orders of magnitude slower than commercial sinker EDM machines for sure, and probably very slow compared to cutting metal with regular tools too. On the other hand of course you can machine almost anything conductive with it :devious:
So anyway, what I'm wondering is... would people be interested in this as a product? I see it as a kit that lets you convert more or less any small mill (or even a router/engraver/whatever) into an EDM mill, and back, not much more difficult than switching regular tools. As far as I know this is pretty unique, and I personally love the idea of it for my own use. I will probably do this regardless, but how much energy I put into it depends a lot on whether it seems to have a market. I'd really appreciate feedback on whether you are interested, and if yes what particular features/requirements you have for it.
Also maybe you can give some feedback on what you see as a realistic price range for this. I expect it will be sub-$1000, ie way below any other comparable commercial machine (even used). Beyond that, I'm not sure myself, I will start pricing the cost of the design after I have it working
Please vote in the poll too.
Thanks!
MLG
