585,557 active members*
3,284 visitors online*
    May 2009
    Need help! Torq cut 22 TLO..
    Hello,
    i have a 95 Bridgeport Torq cut 22 with a DX 32 control that has been working great until... I am having several problems with the tool length offset memory, and with my program files. I lost all of my TLO and my program files. When I looked in the maintenance page I was able to locate my part files (text) and reload them, but all of my TLO were gone. My X and Y Origin ere the same but the Z was reading off the chart. I then tried to Clear all of the offsets and re-enter them with no luck. The BMDC board seems to check out fine, as do the drive boards. Any ideas?? Calling EMI soon but wanted to ask on here to help narrow it down if a board needs replaced.
    Cheers
    Shane
    Nov 2004
    3028
    This is a PC based control and can exhibit ALL the problems of any other PC.
    You need to do a SCANDISK and DEFRAG and check your CMOS settings to see if they are correct for the hard drive you have.
    It is common for the CFGPRMS file to get scrambled. This has the TLOs in it.
    It can be deleted and the software SHOULD make a new one.
    It is also possible that the software may be corrupted.
    George
  1. Bridgeport Torq-Cut TC 3G??
    By Kristjan in forum Bridgeport / Hardinge Mills
    Last Post: 11-02-2017, 11:47 AM
  2. Torq-Cut - Help Needed
    By Engine Tech in forum Bridgeport / Hardinge Mills
    Last Post: 01-04-2012, 07:43 PM
  3. TORQ-CUT 22 Problems
    By tpmx57 in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2009, 02:13 AM
  4. DNC to TOrq Cut 22
    By Drexelracing in forum Bridgeport / Hardinge Mills
    Last Post: 01-16-2009, 11:51 PM
  5. Torq Cut30
    By 600mtc in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2008, 02:46 AM
