585,930 active members*
3,613 visitors online*
    Oct 2007
    31
    Setting the backlash on End block
    I am using thompson ball screw, ball nut and end block for both my X and Y axis.
    Recently connected the motors and have everything moving properly.
    Does anyone know the procedure for setting the proper backlash on the end block?
    I am not certain what the tolerance should be?
    Dec 2007
    379
    There should be zero backlash in a fixed end block. There is a specified torque (you will need torque wrench) for the nut or preload in the manual. I would preload no more than 10% of the max axial load rating on the fixed end block. Ten Percent seems to be the max recommended by ballscrew manufactures in general for preloading their ballnuts and I imagine would they recommend for ball nuts would be similar.
    Or you can do what I did. Tighten it down until there is no backlash and everything spins nice and free.
    Oct 2007
    31
    Thanks for the reply, I was most likely going to go with the second option and tighten it till it "feels" good. Which brings me to my second question...what type of wrench to use...
    I have a torque wrench, but any idea on what these type of nuts are called? It looks like it takes a type of "spanner" wrench for lack of a better term.
  1. touch probe/Z0 setting block advice
    By dougie329 in forum Controller & Computer Solutions
    Last Post: 11-18-2009, 10:44 PM
  2. Setting Backlash with Turbocnc
    By ecope in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-11-2009, 08:36 PM
  3. Replies: 8
    Last Post: 03-10-2008, 09:35 PM
  4. Servo idea - elimated backlash - zero backlash !
    By synthetiklone in forum Linear and Rotary Motion
    Last Post: 12-06-2006, 08:35 PM
  5. RS232 program block by block
    By smoregrava in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2005, 07:52 AM
