585,987 active members*
4,436 visitors online*
Results 1 to 10 of 10
    Dec 2009
    41
    New to me Tree 320
    Does anybody have any info on a Tree 320? I currently have nothing.
    Feb 2008
    243
    I have all thje doc for the J300 which I can email you . They should be similar. to the 320
    Quote Originally Posted by ktmrider View Post
    Dec 2009
    41
    Great! I send you a PM. Thanks.
    Jun 2007
    190
    I have a Journeyman 320 which came with the wiring prints and maintenace manuals.
    I bought the "Operating and Programming Manual" seperatley but it didn't have anything to do with my machine. If your machine has a CRT and takes regular G-code then the manual I purchased is probably correct for your machine. If your machine is like mine, then I don't have a manual but this sample code template should get you started.
    Pete
    Attached Files Attached Files
    Dec 2009
    41
    The machine is actually a Journeyman 330. I was mistaken earlier. Does anybody have the electrical prints for a 330?
    Dec 2009
    41
    Thanks for the code help P!
    Jun 2007
    190
    I made a custom post-processor for VisualMill 6.0 if your machine uses the same syntax as mine.
    The machine will accept modal commands but I find it easier to debug hand written code if I put in all the fields. There isn't much need to hand edit with VisualMill so my post-processor uses modal commands which reduces the file size by about 80%. This comes in very handy on a machne that communicates at 1200 BAUD and only has 64K of program space.
    Pete
    Jul 2017
    5
    Re: New to me Tree 320
    Would you share a pdf copy of the maintenance manual with me?
    Thank you very much
    checkko
    Jun 2007
    190
    Sorry for the delay in responding but it is a pretty old thread. ;-)
    I actually have quite a bit of documentation that came with the mill. It will take a while for me to find time to scan it all.
    Attachment 487020
    The large one on the left is wiring diagrams.
    Aug 2012
    44
    What controls does it have? I have Install and Operation manuals for the Dynapath Delta 20, along with some remaining hardware (control panel, etc.).
    I also have a complete Delta 50 system complete with manuals as well that is no longer in use.
    I upgraded my J320 to a Mach4 system that uses the original servo amps and brushed servo motors.
  1. Tree 325
    By sortafast in forum Tree
    Last Post: 06-17-2013, 08:55 PM
  2. Tree 325
    By jdracing in forum Tree
    Last Post: 04-17-2010, 03:33 AM
  3. tree 2uvr-c tree mill
    By willcofab in forum Tree
    Last Post: 06-11-2009, 07:40 PM
  4. Tree 300
    By catskin in forum Tree
    Last Post: 12-31-2007, 07:43 AM
  5. tree 425 cat 40 help
    By stanglou in forum Tree
    Last Post: 02-22-2007, 12:08 PM
