585,880 active members*
7,904 visitors online*
    Dec 2009
    539
    Exclamation Program Input/Output freezes! HELP!!
    I am having a communication issue with a Hitachi Seiki HT20SIII with Seicos Multi Control (1996). What had happened was, while I was sending a program to the machine from my computer, and the transfer was still in progress when someone accidentally hit the "emergency stop" button. I restarted the machine, but now when I go into "Edit" mode, and no matter what I choose (send, recieve, etc...) it shows the usual screen, but it has no programs listed, no communication parameters (Baud rate, RS232C, etc) are listed. So if I try to input a progam, instantly the whole thing freezes, and I hear a 'CLICK' coming from the back of the machine. You cant do anyting after that, no buttons work at all. If you have any idea, please help me out. If you need more information let me know and I will update my post.
    Dec 2009
    24
    email one of the posters with your machine and ask them.
    link: http://www.mmsonline.com/dp/forums/f...id=24762#24762
    Dec 2009
    24
    Hello! If its your computer, you remove the round cmos battery and replace it..that reloads the bios to factory settings. On the lathe controller can you disconnect and reconnect the power and let the device reinitialize itself with out harm? Also, google for your machine and find someone who has one and do an out of the blue.."found you had a machine like mine" email and ask them, chanches are very good you would get some response. Make sure you have the operating manual..you might be able to get one frree at ebama..look for your machine in advanced google search specifing pdf as file type
    andy
    good luck
  1. program input/output with RS232 port on Mitsubishi 50L
    By Chuck Reamer in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-21-2013, 08:56 AM
  2. Send/receive program without output/input push
    By padobranac in forum Fanuc
    Last Post: 10-20-2010, 03:53 PM
  3. Replies: 2
    Last Post: 12-23-2009, 11:58 PM
  4. Communication Input / Output Program SEICOS MULTI
    By shas595 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-21-2009, 03:14 PM
  5. CNC Lathe Problem - Program Freezes up
    By Crashmaster in forum Uncategorised MetalWorking Machines
    Last Post: 03-28-2007, 01:54 AM
