The VFD connector allows you to control a Variable Frequency Drive (VFD) that is used to control spindle motors.
These drives can accept an isolated 0-10V control voltage that is used to set the speed of the spindle. The VFD connector presents the signals;
- +10V Supply Input
- Control Voltage output
- +10V supply Ground
These 3 outputs can also be used to control many of the DC motor Speed controllers such as the KB Electronics KB-120drive and others. These 3 signals replace the manual speed potentiometer on the drives.
Cheers,
Peter
Homann Designs - http://www.homanndesigns.com/store
