Any ideas if its possible to source a USAGED-09AS1 servo motor. I need a replacement as mine is toast, encoder aswell. Thanks in advance.
Hi PaulRP
You could try these people for your motor, if you can change the shaft to a straight shaft instead of the taper shaft it may be easyer to get a motor that will do the job
http://www.lektronix.net/search/+/ya...ories/+/30/15/
http://www.euautomation.com/search.php?q=&em=3084&p=9
Both of these companys have your motor listed
Mactec54
Many thanks mactec54. Have already tried Lektronix. None in stock and they can'nt source spares for encoder. I have sent an enquiry to euautomation. Thanks again.
Hi PaulRp!
Could you please tell me the USAGED-09AS1 motor's servo drive model number may be i can arrange for you.?
The motor is on its way back from Lektronix. As soon as it arrives I will get the number and send it to you. Many thanks
