584,865 active members*
4,913 visitors online*
Results 1 to 16 of 16
    Nov 2007
    68
    Question touch probe rotation cycle
    dear all,
    i have the following question
    1- if i have an inclined (not straight) rectangular block on machine bed, how to get its center points (in X and Y) with the inclination angle ?? i mean how to use axes rotation cycle to measure this inclined block via touch probe??
    the machine control is Fanuc 0imc
    the touch probe used is : Blum TC50 ( a German brand like Renishaw )
    the macro used in measuring cycle in attachment (the main macro is 9700 and all sub macros from 9701 to 9709)
    Attached Files Attached Files
    Feb 2006
    1792
    On a 3-axis machine, it may not be possible.
    State your problem more clearly, preferably with a drawing, and write what exactly you want to measure.
    I am not able to open the file attached by you.
    Nov 2007
    68
    thanks Sinha for your reply,
    the problem in details as follow:
    i want to measure the center point of a rectangular die on machine center bed.
    we usually use a dial indicator to make this die 100% horizontally .
    we need to use this Blum to measure the center point of this die without using indicator (to save setup time).
    the machine move as photo number 1 and this cause the center to be wrong.
    we need to make the machine path like photo number 2.
    i hope it's clear now
    for the file in previous attach it was for measuring cycle (macro programs ).
    i will attach it again.
    Nov 2006
    175
    Measuring center points by X and Y (look at brown lines) will give you the figure center. After that you should measure also the rotation angle
    Feb 2006
    1792
    I have derived formulae for a similar problem (finding the angle of an edge, and the coordinates of the lower left corner of a rotated rectangle). If you are interested, let me know. I would post these here.
    Nov 2007
    68
    yes please we need this formula badly
    Feb 2006
    1792
    Formulae attached.
    I located the lower left corner, and the angle of the lower edge with X-axis. You need the center. So, more derivation is needed, after touching the workpiece from all sides.
    Nov 2007
    68
    Dear Sinha,
    the document you attached is helpful, but what if i need the coordinates of program zero point to be in the center of the workpiece (i mean not in the lower corner) ??
    is it possible, if yes how can i do this ??
  1. Touch Probe
    By Babba in forum Syil Products
    Last Post: 03-11-2022, 04:36 PM
  2. Caution While Using Your Touch Probe.
    By Willyb in forum Tormach Personal CNC Mill
    Last Post: 08-10-2008, 09:14 PM
  3. Touch probe for sale
    By cut more in forum Digitizing and Laser Digitizing
    Last Post: 03-08-2007, 12:50 PM
  4. Pop-up tool touch probe
    By dmealer in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2005, 12:47 PM
