Originally Posted by
guy2b1
I have already build my own CNC machine and im planning to cut papers, cartons, vinyls, stickers, thin foams, etc. how can I attach an ordinary hobby knife cutter to replace my spindle? What if I want to cut complex shapes, will the cutter be able to rotate to follow in different directions? Please help on how to construct my very own cutter
To try it out you could mount the knife in ball bearing so it can freely swivel. Mach3 also has tangential knife control using a 4th axis to maintain the knife on a tangent to the line/arcs.
On my Roland vinyl cutter the small carbide blade is held in bearing and is a 45 degree angle on the sharp edge. If you go on ebay and search for vinyl cutter supplies you will see many examples and can just buy the cutter and cartridge that holds it.
Mike
Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
