585,992 active members*
5,764 visitors online*
    Nov 2008
    27
    Mach3 blue screen
    This is the path that I took in Mach3 view, Load screens, addons, circle center, circle center set the back to mach3. Now all I have is a blue screen. What did I do wrong and how do I get the main screen back?
    Sep 2007
    359
    Tony,
    You went wrong by selecting a screen out of the main Mach3 folder, just go back to the main Mach3 folder
    Lathe screen files end in *.lset, mill is *.set
    So if you are using lathe you have to change the files of type to suit your machine
    If you want to use a third party screenset it may have to have the bitmap files added to the folder BITMAPS there are two folders there one for lathe and one for mill
    Phil
    View>Load Screens and choose 1024.set in the main Mach3 folder.
    You tried to load a wizard screen. You need to just run the wizard from Mach3.
    Nov 2008
    27
    Thanks for the help. The 1024 did the trick.
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Only get blue screen
    By gabby in forum Cincinnati CNC
    Last Post: 12-16-2009, 07:14 PM
  3. Mach3 Mill Blue Screen of Death.
    By Dougal in forum Mach Mill
    Last Post: 09-28-2009, 01:06 AM
  4. Mach3 View Screen too BIG
    By Mr.Chips in forum Mach Mill
    Last Post: 01-01-2009, 10:35 PM
  5. blue screen of death
    By norvil1 in forum Machines running Mach Software
    Last Post: 10-15-2006, 09:24 PM
