Originally Posted by
MrWild
Yes, an X2. Actually, I won the three G251s by guessing the number of components back when they came out. The Campbell BOB was bought four years ago when I thought the high power UHU servo boards were going somewhere (for an upgrade on the Supermax). The Smarbaga boards I bought had inherent problems that caused them to blow up so I never used them while I waited for a fix that didn't happen. The G201 was from a different deal so all have been sitting on the shelf. Yes a G540 is nice, and I have one on a JGRO which will move to a Joe2006 some day. Total cost so far is for the unused Campbell BOB.
Understood. You sure can't beat that G251 price. LoL.
I thought people were using the 906ozin steppers on the Z axis to keep from using counterweights and air springs. Is that only on the X3?
Yes. Because of the weight of the X3 head, it MUST have a N34 motor of 640 oz to lift it properly. Prior to my developement of G540/906 use, the G540 could not be used with X3 because no applicable N34 motors seemed to exist. Detuning the 906 for G540 just happens to be workable. NO X2 will ever need a N34 though.
Why are people using counterweights and the 381inoz motors on the X2 then?
You really don't need a counterweight with the 381--Unless you are trying to wring out every last bit of Z axis speed. People with less efficient drivers/motors/PSU combinations may NEED a counterweight though.
The little G250 inside a G540 will drive that 906 motor, lift that heavy X3 head--and run that Z at about 200 IPM with NO counterweight.
Let me put it into perspective for you:
The HEAD on an X3 weighs about as much as the ENTIRE X2.
I also thought it was advised to use 270ozin steppers on the X and Y as they keep their torque into higher revs for faster rapids. While I have the drives and BOB, the steppers are still being decided.
That was in the "old" G540 days. The 270 CAN do the job, but the new 381 motor is such a good match for your 251 driver and 48V PSU, (and will drive to even higher RPM than the 270) that I now recommend it for all three X2 axes.
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
