585,749 active members*
3,872 visitors online*
Results 1 to 7 of 7
    Sep 2009
    91
    MORI SEIKI SL1
    I have a Mori Seiki SL1 lathe with Fanuc 11TE control.We used the machine without a barfeeder and we want to use now with barfeeder.But now we have problem with chuck.Chuck only clamp(M10) but don't want to unclamp(M11) the piece.Before we buy the machine,she was feed by robot hand.Can someone help me?????
    Feb 2006
    992
    Did you check and see if the foot unclamp option is on. I never saw SL1 but I used to run a NL2500Y so assume this machine have same interface, if it is similar it should be it.
    The best way to learn is trial error.
    Sep 2009
    91
    mori
    where can i check this option? In parameters?
    Jun 2009
    28
    Are you making sure the spindle is stopped before giving the M11 command? If I'm not mistaking there is a command that links the machine to the bar feeder and with out the command it will not work as intended.
    Feb 2006
    992
    Quote Originally Posted by tano View Post
    Keep press NEXT(arrow softkey).
    Sep 2009
    91
    mori
    Quote Originally Posted by newtexas2006 View Post
    Can you be more precise please?
    Sep 2009
    91
    mori
    Thanks for your help guys.The problem was when machine is in MDI chuck not clamp but in AUTO mode there is no problem.Who knows :-))))
  1. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  2. Mori Seiki Sv-503
    By mr-seiki in forum Servo Motors / Drives
    Last Post: 06-04-2010, 02:52 AM
  3. mori seiki?
    By manuelc149 in forum Uncategorised MetalWorking Machines
    Last Post: 10-25-2007, 12:15 AM
  4. Mori Seiki SL-204
    By dcworld in forum Uncategorised MetalWorking Machines
    Last Post: 07-28-2007, 04:25 AM
