The battery that keeps the memory healthy lasts for many years in normal use so you are probably okay for a few months if it is not a really old machine. Also you may have all the Parameters and Settings on a floppy or usb drive that came with the machine; there is a holder inside the control cabinet door that the floppy is normally in.
One thing to remember when you do get the machine powered up is to run the Run-In program to purge all the oil that will have drained down into the lower spindle bearing; this program should be in the machine. For the Run-In program you adjust the air pressure for the spindle lube to 30 psi and keep checking that the spindle nose is not getting warm while the program is running.
